#16 |
Sponsor: JET DV
<<<-- Originally posted by Chris Sorensen : There's also Moving Picture (www.stagetools.com). There's plugins for every editor plus a standalone app. -->>>
Not EVERY editor - Vegas isn't listed. Of course, it would be redundant to the built-in capabilities. |
#17 |
You're right, you got me. But there are plugins for:
Adobe Premiere_ (Win/Mac) Adobe After Effects_ (Win/Mac) Apple Final Cut Pro Avid_ (All Editors Win/Mac) Canopus RexEdit / DVEdit / DVStorm Discreet_ edit DPS Velocity FASTStudio IMC Incite In-Sync SpeedRazor Lightworks Media 100 (Mac) and 844/X (Win) Pinnacle_ Ulead_ I guess with Vegas you'd have to use the standalone version if you wanted to use it. |
#18 |
Vegas has the easiest most comprehensive tool (pan/crop) for this sort of work out of the box. Once in pan/crop, regardless of the image size- simply right click and choose match output ratio and it automaticlly adjusts for any dimension ratio discrepencies. Ed can correct me if I'm wrong but beings the fact Vegas is format agnostic image resolution is a non-issue. It can handle small and large images alike.
It's incredibly powerfull and infinitly more easy than any other tool from other NLE's I've tried. |
#19 |
Sponsor: JET DV
<<<-- Originally posted by Glen Elliott : Vegas has the easiest most comprehensive tool (pan/crop) for this sort of work out of the box. Once in pan/crop, regardless of the image size- simply right click and choose match output ratio and it automaticlly adjusts for any dimension ratio discrepencies. Ed can correct me if I'm wrong but beings the fact Vegas is format agnostic image resolution is a non-issue. It can handle small and large images alike.
It's incredibly powerfull and infinitly more easy than any other tool from other NLE's I've tried. -->>> Agreed. That's the reason I said it would be redundant. |
#20 |
You don't really need to get a plugin for this technique. All you have to do is import your still into any NLE then keyframe the position and scale parameters.
#21 |
True however some NLEs are much more intuative in doing so. I remember the Premiere Motion tool being a dread to work with for complex movements and keyframing.
#22 |
While Ken Burns is great, check out a film called, "The Kid Stays in the Movie," to see some more interesting techniques in still photo compositing. These people have really raised the bar for this type of filmmaking. And damn entertaining besides.
Wayne Orr |
#23 |
Wayne, do you mean The Kid Stays in the Picture?
#24 |
Indeed. Thanks for correcting me.
Wayne |
