Home theater question at DVinfo.net
Old September 17th, 2008, 01:14 AM   #1
I saw a subwoofer today that had connectors for the surround speakers and the front and center channel. I guess the subwoofer's amp powers everything? The subwoofer was a Polk. Anyone used a system like this?
Btw, I checked the AVS forum, some of the threads of hundreds, even thousands of replies. Not sure how anyone can use that resource any more.
Old September 17th, 2008, 02:00 PM   #2
I picked up a big subwoofer on sale last year. Connected it to my HTDV via the video out left+right pair of RCA plugs. The subwoofer has left and right output RCA plugs - possibly a center channel (which I don't use). I don't have a real "home theatre" sound system though, just a pair of power studio monitors which are plugged into each channel.
But I don't think the subwoofers will power everything (unless part of a matched package of components). I know that mine has line level outputs which need amplification.
Old September 17th, 2008, 04:05 PM   #3
Hi Brian,
If you've got the model number, or can remember clearly what it looked like, just go to the Polk Audio Site and find it - then check it's specs.
Should be easy to figure out.
I'm running a full home theater system, with a 65" HD Mits, and a 109" Screened HD Optoma Projector unit.
Harold
Harold Schreiber is offline   Reply With Quote
Old September 18th, 2008, 11:06 AM   #4
I have a polk with the same connections.
No, the subs amp wont power everything...just the sub. It's some sort of a "pass through" way of connecting it. You will supposedly get more bass this way, but depending on your setup, it might require a lot more speaker wire.
I have mine just connected with the RCA input...it sounds fine.
FEELING CREATIVE? feeling-creative.com
AbsoluteMotionVideo.com
Mike Meyerson is offline   Reply With Quote
Old September 21st, 2008, 01:19 AM   #5
That makes sense, if it powered everything there'd have to be a volume control.
Brian Luce is offline   Reply
