Digital Cinema devloper at DVinfo.net
Go Back   DV Info Net > The DV Info Network > These Are the People in Your Neighborhood
Introduce yourself! Who you are, what you're doing & using.
Old May 2nd, 2011, 10:23 PM   #1
Hi,
I am Venkat from India. I am currently developing an E-Cinema server.
I am considering to use cineform as the playback format as I am extremely satisfied with the quality.
I have worked a lot on Look Up tables and on the way to build a custom mastering tool which accept DPX/TIFF files and apply a look up table and encode video in the desired format.
I am also looking for collaborators who can work with me on implementing HDCP
Venkat
Venkat Siddareddy is offline   Reply With Quote
Old May 3rd, 2011, 12:22 AM   #2
Images: 18
Re: Digital Cinema devloper
Hi, Venkat,
always good to see another member from India (my favourite country), grossly under represented here on DVinfo.
Can't help you with your aspirations, as it's a bit (a bit? Huh!) out of my area of expertise, but I'm sure someone will appear out of the woodwork.
Enjoy the site and I really hope you can hook up with a suitable collaborator, sounds like a fascinating project.
Go for it, my friend.
CS
Old May 4th, 2011, 10:23 PM   #3
Venkat...what is the point of using Cineform, if the delivery is ultimately TIFF/DPX? It takes up too much space and you'll probably have to pay licensing fees which will bite you in the future. DCI uses JPEGs, which is good enough.
If you are in for the long run, I suggest you patent your own image sequence playback platform. Otherwise you will forever rely on third-party for support.
Or, you might go a different route and try MPEG-4 (like UFO) or MPEG-2 (like Interworld Digital).
Hope this helps.
Sareesh Sudhakaran is offline   Reply
  You are here: DV Info Net > The DV Info Network > These Are the People in Your Neighborhood
