filming in mirrors/reflections at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old April 13th, 2007, 09:13 AM   #1
I'm working on a project and one of the shots calls for a reflection in the mirror, much liks zach braff in garden state. But I obviously dont want to get the camera in the shot. Has anyone done shots like these? If so how do you go about it. Thanks in advance
Nate Benson is offline   Reply With Quote
Old April 14th, 2007, 12:09 AM   #2
The only way I know of to handle a mirror is to shoot it at an angle. You may also need to set up your scene so it looks normal on camera even though the talent may not be able to see themselves clearly in the mirror. Changing the angles for the camera may look weird to you on the set, but the only thing that counts is how it looks on camera.
Old May 1st, 2007, 04:42 PM   #3
Yep, you obviously can't be straight on, so you're going to have to try and find some interesting angles to show your reflection.
Talenos Productions at http://www.talenos.com
Matt Newcomb is offline   Reply With Quote
Old May 2nd, 2007, 10:44 AM   #4
Or you might not use a mirror at all, instead putting a green screen in the frame in place of the mirror and compsiting in a shot to make up the "reflection."
Old May 11th, 2007, 05:22 PM   #5
Or even go the whole way and build a fake wall with a mirror hole in it, use a stand in/double for the back of the head and have your actor facing out from behind the mirror hole, if you see what I mean (see whichever marx brothers film it is that uses this technique...)
Paul Jefferies is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
