50p to 25p, more filmic? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old December 10th, 2006, 06:32 PM   #1
Will 50p converted to 25p look any different? The 50p looks very "live", but 25p has a better look. By converting 50p to 25p, will that give the same effect as if the footage was shot in 25p?
Also, how are the NLEs actually converting the footage when a 50p footage is put on a 25p timeline (pulldown etc)?
Nima Taheri is offline   Reply With Quote
Old December 11th, 2006, 03:42 PM   #2
25p is 25p, so if you make it 25p it will be 25p
Northweststockfootage.com
Shooting 100% HD
Washington, Oregon, and Soon British Columbia
Mack Fisher is offline   Reply With Quote
Old December 11th, 2006, 03:51 PM   #3
yes, but how do the NLE's convert the 50p to 25p, just remove 1 frame for each 2 frames?
Old December 11th, 2006, 09:22 PM   #4
more than likely it will interpolate the 2 frames into the on, however this is dependant on ur NLE...
Peter Jefferson is offline   Reply With Quote
Old January 12th, 2007, 05:35 AM   #5
To be shure to drop every second frame i use VDub - works perfectl
Greeting Richard
Richard Firnges is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
