Correct Settings On VX2100 For Film Look? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old November 4th, 2006, 03:16 PM   #1
hello.
what would be the correct and most suitable settings for shooting a neutral video on vx2100 - exposure, shutter speed, white balance, etc - if i aim to give the footage a film look in post?
thanks.
"I do detest everything which is not perfectly mutual."
Lord Byron
Aram Rian is offline   Reply With Quote
Old November 16th, 2006, 11:52 AM   #2
Here we go, lol...
From all the research I have been doing lately I would say this...
Shutter = 1/60th (60i)
Aperature = Wide open, no gain, ND1 or ND2 or none depending on amount of light
White balance = normal for the scene
If you have a 35mm adapter, that is your best bet. If not, backyard DOF.
Then use something like DVFilm Maker, Magic Bullet, or VirtualDub to convert the footage to 24p, then edit, then port back out to whatever format you want.
Use slow pans, and try to get that DOF you see in movies. Play with the sharpness, maybe turn it down one or two.
I have this same camera and was testing yesterday. Those settings and DVFilm Maker made my footage look as close as it gets for what I have to work with. Since you are in UK, I assume PAL, you may have to slightly modify those mentioned settings.
www.facebook.com/projectspecto
Marco Wagner is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
