Lighting for a Bar Scene and Motel scene - Page 2 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old July 7th, 2006, 05:58 AM   #16
It actually is, I believe, video noise. Because the GL2 doesnt do low light levels exceptionally, and because I under lit it, the gain on the camera was up way high.
I am adding a low level back light and a small fill to one side to bump up the brightness just a tad, and to be able to lower the gain.
The settings on the camera I want is:
Shutter: 1/60
Iris: 2.0
DB: 0
16:9
Frame Mode
Steve Maisch is offline   Reply With Quote
Old July 7th, 2006, 05:24 PM   #17
That is a good idea. You can (and often must) use very bright lights to achieve a dark look. It is more the lighting ratios/contrast and shape that determine the look than actual brightness.
Marcus Marchesseault is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
