New Film Look and color correction software at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old March 31st, 2006, 01:44 PM   #1
I am a relatively new user of this forum, and it has been a very enjoyable experience. So I am releasing this information here first...
After 10 years of experience with CG and 3D graphics programming Mente Magica released a new software application for color correction and "film-look":
tungsten|SOLID: CinemantiQ
Unlike other solutions, this is a stand alone application. The ease of use is unprecedented, due to a UI design that gives you instant feedback and many actively visual controls. You will be working on your own project in less than 5 minutes.
Aside from that, it is really fast when compared to some AfterEffects plugins or with manually created layered effects. (quick setup and quick rendering!)
Some features:
-Color correction (3-point histogram+hue, tint, saturation, RGB channels)
-Diffusion and Bloom simulation
-Bleach bypass physical simulation
-Gradient lens
-Simple noise reduction + grain
-Video block segmentation
-Preset library (more than 50 looks included and more coming)
-Smart fast deinterlace
-180° rotation for 35mm DOF adapter users
-Batch processing
-Pdf manual + flash tutorials
-Fast and affordable
You are invited to take a look at:
http://mentemagica.com
Here is the press release information: http://dvinfo.net/conf/showthread.php?t=64101
Also, there is an introductory offer of $99.99 USD for the first 99 sales. (Retail price is $350)
Comments, suggestions and questions welcome.
Alain Bellon is offline   Reply With Quote
Old March 31st, 2006, 02:07 PM   #2
Okay Alan, I ve ordered and am downloading set up now.
Chris J. Barcellos
Old March 31st, 2006, 02:12 PM   #3
Excellent Chris. You may PM me if you have any particular questions.
Old March 31st, 2006, 02:34 PM   #4
These questions will be asked by others, I am sure, too, so here are some 1st Questions:
1. I m trying an HDV file. Is that going to work ?
2. How do I get to .pdf Manual and Flash training.
3. What are possible output selection in terms of file formats.
Comments: Interface looks pretty nice, now to see what we can make of it.
Chris J. Barcellos
Old March 31st, 2006, 02:49 PM   #5
1. I m trying an HDV file. Is that going to work ?.
For input, CinemantiQ should have no problem reading your HVD file provided you have the appropriate DirectShow codecs. For output you will need a type 2 codec, I do not know if the HDV codec you have is compatible with VfW and type 2 DV. Go to render movie and the Video tab will show all available codecs for output. Keep in mind that not all codecs support all kinds of resolution. For production work I usually recommend the HuffYUV codec for output since it is a lossless compressor that will preserve your video quality until the final encoding. You can find the HuffYUV codec here: http://www.free-codecs.com/download/HuffYUV.htm
2. How do I get to .pdf Manual and Flash training..
You can either find the PDF file in the installation directory or simply click on the Help menu to get to the reference guide. The Flash tutorials can be accessed through the PDF, or by manually opening the HTML files in the installation directory.
3. What are possible output selection in terms of file formats..
The output formats are AVI (supported codecs) and BMP, JPG, TGA sequences.
Thank you. I hope you can make cool stuff with it.
Old April 1st, 2006, 01:02 AM   #6
says that it has smart deinterlacer...does it also do the math to go to 24p?
Riley Harmon is offline   Reply With Quote
Old April 1st, 2006, 10:11 AM   #7
It doesn't do 24p conversion yet. But it is planned for the next version. The smart deinterlacing will just turn interlaced frames (2 fields) into "progressive" ones.
Old April 2nd, 2006, 09:47 AM   #8
Ok, I bought a copy and have been playing with it for the last hour or so. Two things though. Even when I check off the Save Audio option, I'm not gettting any audio in the output file. For input and output I'm using the CineForm HD codec. Second, there's no 23.976 framerate output option. Other than that it seems like a really nice app. Good speed and nice, clean interface.
Joe
Joe Pasarela is offline   Reply With Quote
Old April 2nd, 2006, 12:24 PM   #9
I found one more problem. The codec config panel doesn't appear even when I have the Show Codec Config Panel option checked. It doesn't matter what output codec I have selected.
Old April 2nd, 2006, 01:05 PM   #10
Joe,
I will verify if there is an issue with the cineform audio stream, and add the 23.976 framerate option. (actually I believe that if you select 24 and your source is 23.976 it will preserve the source's 23.976)
Also will check on the codec configuration panel not showing, but I will need your machine specs and your cineform codec version. I have contacted you privately.
Old April 2nd, 2006, 05:29 PM   #11
A new option for 23.976 frame rate has been added, and Cineform users should have no problems. Audio stream is recorded now and the codec configuration panel is displayed on request.
A new updated version is being sent to all customers.
Thank you Joe for letting us now.
Old April 2nd, 2006, 05:31 PM   #12
Thanks for the superb support Alain. Gotta love indy developers :)
Joe
Old April 3rd, 2006, 10:43 AM   #13
I shoot with a dvx100a will the software work well with 24p ?
Anthony Auci is offline   Reply With Quote
Old April 3rd, 2006, 11:33 AM   #14
Hawaiian Shirt Mogul
is the software internal 8 bit processing ?
or can it process 10 & 16 bit if one has the codec's ?
Don Donatello is offline   Reply With Quote
Old April 3rd, 2006, 01:18 PM   #15
updates
Is the latest updates in the the software that you can download? I just bought and downloaded it and got to thinking about the updates. Thanks
John L Scott is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
