Film look ideas please. at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 24th, 2003, 04:13 AM   #1
I have video footage of two actors, shot in a white environment.
The footage is extremely sharp and toooooo video.
Can anyone help me make this look warmer. What techniques, programs, or AE plugins really work.
I love my XL1 but I'd really like to get a softer, richer look to the piece I'm working on.
Paul Winterton
Vancouver, Canada
Paul Winterton
Cybereyes Images
604 689 3008
Paul Winterton is offline   Reply With Quote
Old January 24th, 2003, 06:20 AM   #2
RED Code Chef
If you want a softer look you can always add (guassian) blurs,
motion blurs, un-sharpen filters etc. And yes, post work can change
the look very much! Changing contrast, color correction (timing)
etc. can change a lot!
Just fiddle around with the filters that you've got in your applications
and you should be able to find a couple that can change your
footage to more acceptable looks. One thing that easily enoughs
changes my footage is to get it progressive (if you haven't shot
it in frame/progressive mode you can de-interlace it etc.) and
add black bars (letterbox it).
Just some ideas and hits etc. Good luck!
Rob Lohman, visuar@iname.com
Old January 24th, 2003, 10:21 AM   #3
what NLE or post production programs are you using?
Kevin Burnfield is offline   Reply With Quote
Old January 24th, 2003, 11:04 AM   #4
RED Code Chef
Well... for my editing I'm currently using Premiere, but I'm also
looking at other products like Vegas Video, Avid, Pinnacle Edition
etc. As for other post work I haven't played enough with the
systems yet. I have access to things like After Effects, Combustion
etc. but not much time to actually take a look at those before I
decide which one I'll go with. I do know that Avid and (especially
the new version 4) Vegas Video have some incredible tools for
altering the picture for being NLE applications!
Most post applicatios (like AE, Combustion etc.) are made for these
purposes and have much tools available.
I even know people who (for short sequences) imported all
the frames in Photoshop and did some image manipulation
in there. All depends on what you have (can afford).
Hope this explained it a bit.
Old January 24th, 2003, 01:32 PM   #5
RE: Photoshop - there is a open source program called FILM GIMP that is out and about that basically will do the same thing as the whole export by frame/import to photoshop/export back to frame and then import back into NLE thing--- I've not had a chance to play with it but I know that the reviews have been great and a number of h'wood productions have used it for stuff like taking dust shadows off frames and stuff.
re: your toning down the background: I've had great luck toying with the color correction tools in FCP to do a lot of stuff I didn't think I could with it.
Not knowing what program you are using I can't say but with the FCP one I can work with a specific color in a shot to alter/enhance/whatever it.
the other things to ask are what are your actors doing? Lot's of moving around?
Old January 24th, 2003, 04:56 PM   #6
Hawaiian Shirt Mogul
for warmer your NLE should have color correction of some kind using your NLE .. if you don't have one yet .. download the beta of Vegas 4 .. www.sonicfoundry.com
for a softer "looK' you might try putting the same clip on 2 video tracks ..
color color correct the TOP track .. and add satuation
2nd track use some type of BLUR FX to soften it ..
then set opacity on top track around 50-60% ( depends on how much BLUR you added) set to your EYE .. always check it on a NTSC monitor ...
Don Donatello is offline   Reply With Quote
Old January 26th, 2003, 12:30 AM   #7
Guest
Posts: n/a
Ideas please
The other suggestions are good ones for post. But before you get to post, consider using a 1/2 black promist filter. I got a very good one from Tiffen, through ZGC, for about $70, if I remember correctly.
Old February 13th, 2003, 04:10 PM   #8
Moderator
Paul,
Monsieur Donatello hit a homerun solution for your situation. What he is describing is similiar to a technique we call "Field Blending" in Final Cut Pro -- or any other NLE program that allows for multiple layers of video tracks and opacity control for each track.
I would say that a combination of *deinterlacing* via field blending and some tasty color/ level correction will yield you at least 90% of the look you are after.
Here's a good link to Field Blending in FCP:
http://www.kenstone.net/fcp_homepage...ideo_film.html
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old February 13th, 2003, 06:43 PM   #9
Does Premiere allow for multiple video tracks?
Imran Zaidi is offline   Reply With Quote
Old February 13th, 2003, 07:14 PM   #10
Moderator
Hello Imran,
What computer are you using? More or less, yes it does - remember though you still have to render out the timeline if you are combining tracks, so you want as fast of a computer as you can get.
If you are on the Mac, you would be getting a better deal with more value even with Apple's new FCP Express
http://www.apple.com/finalcutexpress.
You can download the free 60 day trial of Adobe Premiere 6.0 at http://www.adobe.com/products/tryado...tml#product=42
Keep in touch Imran,
- don
Old February 14th, 2003, 05:15 PM   #11
Hi Don. Actually, I have a PC and I do have Premiere 6.5. I just had never tried the method mentioned above and before I started trying to figure it out, I just wanted to find out if it was even possible and worth attempting.
Imran.
Old February 14th, 2003, 05:33 PM   #12
Moderator
Thank you Imran,
Please keep us posted about your project!
We'd love to hear back from you.
- don
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
