After Effects film look at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old February 1st, 2006, 01:07 PM   #1
Hello to all. I have been given a great technique to use on After Effects.
Here goes...
1- Import a video clip into A.E. (remember to interperlate the footage)
2- Duplicate the footage
3- On the top layer of the video: Apply a Gaussian blur-10; apply Levels next-bring the both little handles on the histogram in a little on each side. I wish I could explain this part better. I belief this sures up the contast; Finally, set Opacity to 50%
Then insert 2 solids in between the 2 video layers
4-Shadow Layer: create a solid (orange/warm=O' Brother look or blue/cold=Matrix look) Opacity 10% to 40%
5-Highlight Layer: create a solid (white or aqua) Opacity 10%; other adjustments to fool around with on this layer-Curves, Levels, Hue/Sat.
I used this technique on some pictures with stunning results! I suspect I could also add some Noise too.
Does anyone else have any other film techniques they use with After Effects?
-Mike
-Mike
Mike Cornett is offline   Reply With Quote
Old February 1st, 2006, 02:01 PM   #2
Well there is always the fake bleach-bypass look:
- Duplicate footage
- Make top layer black and white
- Select Screen transfer mode for top layer
Optionally:
- Apply Levels to top layer and adjust to liking
JF Robichaud
Jean-Francois Robichaud is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
