Question about adding CGI and visual effects to your 60i to 24p footage. at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 16th, 2006, 09:27 PM   #1
I'm using DV filmmaker for the 60i to 24p conversion. My film has CGI and visual effects and will be transferred to film. How do I output for the special effects additions. Do I add the effects to the original 60i footage? Do I convert it at STRAIGHT 24P without any pulldown and add the effects? Or do I add the 2:3:3:2 pulldown to the footage and THEN add the effects?
James A. Davis is offline   Reply With Quote
Old January 17th, 2006, 12:51 AM   #2
Hawaiian Shirt Mogul
if you are doing the 24p conversion ..and you are delivering the project to your tape to film house on hard drive = you can deliver 24p files .. then i would leave CGI 24p ..
render you project in pieces ( number them & CGI clips ) and be sure to include numbers on the CGI where they should go as in all sequencial numbers ...
if you need to composite the CGI with 60i clips then convert the 60i sections to 24p and composite the 24p CGI and render out 24p ...
check with your tape to film house as most want it in pieces ( approx 18-20 min max sections) .. you can also check with them on the CGI ..
Don Donatello is offline   Reply With Quote
Old January 17th, 2006, 12:40 PM   #3
What if we decide to go straight to DVD? Is there a way to compromise.
Are you saying 24p with no pulldown at all? And also render each effect at 24P seperately on each frame?
Old January 17th, 2006, 11:20 PM   #4
if you are shooting for a film transfer then it's 24p all the way ...more then likely your transfer house will prefer 4:2:2 files vs 4:1:1 ..so if you do have a 4:2:2 master and you don't make it to film then after you have you finished 4:2:2 24p files .. take that finished 24p and render out a 24p + pull down for tape ..
Old January 18th, 2006, 12:45 PM   #5
Thanx Don
One more question though. When I played some of my footage (with 3:2 pulldown) on my widescreen tv (and the footage was cropped so it fit the tv) the image wasn't that clear. If you have enough money will is there a place that will convert your footage into HDef. I know if wouldn't be true high def but they can make it look better for High Def TV's right?
Old January 18th, 2006, 01:00 PM   #6
If you've shot 60i and plan to do CGI effects for 24p, you should consider performing the 60i->24p conversion at the front of the pipeline. Then you have all your plates in 24p, and you can handle everything uniformly through the entire pipeline including matchmoving, animation and compositing.
If you want to convert to hi-def, I would also recommend making this conversion PRIOR to adding effects. The thing about CG renders and digital mattes and other digital effects is that the focus, color space and noise and such are subtly different that the original plates.
You see this all the time in bad/cheap composits in some productions, but even if your effects crew is really good and gets the shots looking great on SD source, color grading and other attempts at enhancing finished shots in the up-conversion to HD can bring out the differences between live and CG assets, wasting all that fine work to get comps to match so well in the first place.
For a filmout, you may want to consider a final render to Cineon, OpenEXR or even just TIFF or TGA image sequences rather than printing to a SD tape.
Nick Jushchyshyn Matchmoving, Compositing, TD
imdb
Nick Jushchyshyn is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
