How would you compare the noise (grain) on a DVX-100 to a Sony VX series. at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old December 28th, 2005, 07:59 PM   #1
When I use the DVX-100 i see alot of noise as much as when I use the VX-1000 or 2000. Whats that about? Are my settings wrong?
James A. Davis is offline   Reply With Quote
Old December 29th, 2005, 08:39 AM   #2
What are your gain settings? If you are shooting in dim conditions and your camera is compensating by raising the gain, the graininess and lack of color will become apparent. The VX2000 is considered a very good camera in low light, so it may actually have less grain due to less gain needed in low light. The only factor that causes "grain" is gain, so look there first then look at other settings that may be causing the gain to automatically increase. Make sure you don't use too severe of a ND filter that may be causing gain increase.
Old December 29th, 2005, 11:58 PM   #3
The DVX is a noisy camera, the 100b is the best of the bunch. That is the price you pay for more saturated colors.
ash =o)
Ash Greyson is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
