safest way to crash a car into a tree? - Page 4 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old February 9th, 2010, 01:32 AM   #46
Originally Posted by Alec Wheeler View Post
I like the idea of the trees perspective as well. with increased zoom, don't you loose depth perception?
Yes, that's precisely why you do it this way. If you shoot the oncoming car from some distance behind the tree and keep the tree in frame, you could cut while the car is still several meters from the tree but it'll look like it's a few inches.
Jacques E. Bouchard is offline   Reply With Quote
Old February 9th, 2010, 02:08 AM   #47
it is like jumping from a plane without a parachute. until you are about one inch from the ground, not much has happened, no damage yet. and how much of a problem can one inch possibly be..
anyway...
I would try to do the whole driving - skidding - swearing - panicking all the way up to the tree, then cut to the "unmounted bouncing camcorder with flying shards of glass" (maybe even some shards thrown from the rear seat) and then cut to the car from the outside, front wrapped around the tree. The back of the car lifted by wire attached to a crane, then the car drops and does the "little post crash bouncy thing" then you rotoscope the wire out. or if you don't want to do that, just frame it to the middle of the rear wheel, not showing the wires.
You don't have to lift the car very high, a foot or so should be enough. you could possibly even lift it using a lever, which you suddenly let go.
Oliver Neubert is offline   Reply With Quote
Old February 9th, 2010, 07:35 AM   #48
how am I gonna get hurt pushing it into a tree with a tractor? it's no different than digging into a big pile of rock hard dirt. It wont be fast, that's what post is for. I think this is going to turn out great.
Physics, that's how. To simulate the same amount of damage to the front of the car by pushing it from the rear will require much MORE energy than crashing the car. You are attempting to transfer energy from the rear the full length of the car to the tree. Thinking that it will be similar to digging in hard dirt is wrong.
Let's see, you would need a very large tractor that could maintain traction that could generate sufficient energy to crush the car against a tree and you can't see how you or worse yet, a bystander be injured?
David Chilson is offline   Reply With Quote
Old February 9th, 2010, 11:55 AM   #49
Originally Posted by Jacques E. Bouchard View Post
Models are a terrible idea. It'll all look fake and amateurish.
More or less amateurish then purposely driving a car into a tree?
Honestly I'll agree its not the best idea, After Effects is, but for some reason he can't use it (or get someone else to do it for him).
Independent Filmmaker in Canada's Capital
Graeme Hay is offline   Reply With Quote
Old February 9th, 2010, 01:36 PM   #50
the front of the car will be SIGNIFICANTLY weakened. It'll have the engine and radiator and stuff out. the innerfenders will be gone, everything making the front clip rigid and strong will be cut or removed. it'll crumple like a tin can up until the K member, and I don't need any more carnage than that. it's not gonna get a moving start. that's more dangerous than crashing the car. just rest up against it and slowly push it till its "crashed".
Alec Wheeler is offline   Reply With Quote
Old February 9th, 2010, 01:40 PM   #51
actually, a regular floor jack would do just fine. raise it up just a bit, let it fall and bounce. especially if it was raised from say a rear corner. just frame it out of the shot.
Old February 9th, 2010, 04:56 PM   #52
Much more. There's no way of making a branch and a toy car look like a real car and a tree.
And it's not a case of "either/or". I've offered solutions that don't require smashing a car into anything.
J.
Old February 9th, 2010, 05:00 PM   #53
OK, I said this in my first post and people pretty much ignored it, so I'll tell it again: you CANNOT smash anything into a large tree, they are protected by city bylaws - even on private property. You need a special permit to cut a tree in your yard, you sure as hell need permission to smash a car into one - and you won't get it.
Forget smashing anything into a tree. Period. End of discussion. You WILL be fined and may have to go to court.
Old February 9th, 2010, 07:29 PM   #54
were not cutting it down. were not moving it. the way were gonna do it, it won't even damage it. maybe some bark will come off. what does the state care if I push something against my own tree?
Old February 9th, 2010, 10:39 PM   #55
Tell it to the judge. Trees are protected. Period.
Old February 9th, 2010, 11:08 PM   #56
I dunno, Jacques. Oregon's a pretty libertarian place. You can do pretty much anything there, especially if it's on your own property.
Old February 9th, 2010, 11:58 PM   #57
Cities require permits to cut down trees, Salem is no different. And that's not just for safety reasons, but to make sure old trees don't get wiped out for no good reason.
A quick Google search turns up a newspaper article about a Salem developer that was fined $10,000 for cutting down trees on his property without a permit.
If the OP runs a car into a tree, I'd wager dollars to donuts that a neighbour'll call the cops. Especially if it's a large, shade tree. And the next-door neighbour who might suffer damage if the tree gets sick from the impact, dies and falls on his property later on will be most vocal about it.
This thread started out fun, it's turned into a freaking advertisement for the Darwin awards...
Old February 10th, 2010, 12:01 AM   #58
Oliver - interesting example about the parachute. Particularly because Doug Spotted Eagle who posts here often had exactly this problem when he was skydiving and at the last minute lost control of his parachute and smashed into the ground - he nearly died and was hospitalized for an extended period.
And as you say, he was fine when he was still one inch from the ground.
Old February 10th, 2010, 12:24 AM   #59
yeah, I haven't heard of any tree protection programs. I could be wrong, i guess. I know who to ask about it though.
anywho, the car is all fixed up and ready to shoot. gotta clean the interior though.
Old February 10th, 2010, 08:23 AM   #60
So let me ask what the end result of this exercise will be.
A video posted to YouTube?
David W. Jones
www.joneshdfilms.com
David W. Jones is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
