de-interlacing high shutter speed at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old June 29th, 2005, 02:43 PM   #1
i m about to start a music video tomorow with a sony pd-150. we re trying to get that stroboscopic style as in saving private ryan. in order to get that i need to shoot at least with a shutter speed of 1/80(PAL). but i wonder if de interlacing works with a shutter speed over 1/50 since the concept is to turn 1/50 into 1/25(PAL)...
thanx for your help
Yohann Kouam is offline   Reply With Quote
Old June 29th, 2005, 04:12 PM   #2
For PAL, this should work, because it's a 2 field to 1 frame ratio. For NTSC, it's highly recommended against.
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
