Tiffen Ultra Contrast & ND Sequence? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 31st, 2005, 12:57 PM   #1
Hi,
Has anyone used a Tiffen Ultra Contrast filter with an ND filter? I am wondering if there is an order to stack these in to get the best image. Does the UltraCon only work when it gets a lot of light (meaning it would need to be out front)? Or can it still do its thing under lower light (meaning it could be behind the ND)?
The UltraCon 3 is in transit, and I'll test in a few days, but would like to hear others experiences.
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old May 31st, 2005, 03:02 PM   #2
That's a good question, Josh!
I would stack the Ultracon in the front with the ND behind. The Ultracon likes to have the ambient light strike its front surface.
However, it's worth testing when you have them in hand to see which effect you prefer.
Remember with the Ultracons that when you pan off a frame that has high contrast the effect will shift as you move into the low contrast area, which may be visible.
Charles Papert
www.charlespapert.com
Old May 31st, 2005, 04:50 PM   #3
Charles, thanks, I will watch out for camera movement. The shots I plan to use this for are locked down.
I'll follow-up after I test. It is an intersting question, because an ND only lowers the overall light level, it doesn't effect the contrast ratio. Will this thing work in "low-light" situations (i.e., behind an ND)? I'm sure, as with most optics, there is an optimal lighting condition, a sweet spot. Let's see if I can find it.
Josh
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
