50i to 24p Conversion Help at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 12th, 2005, 07:49 PM   #1
I've been search through the forums but can't find an answer, so please give me a quick hand ;)
I'm shooting a documentary with a Sony PDX-10 PAL this summer, which shoots at 50i. I'm looking at possibly renting a DVX100A as well, and am looking at methods to convert 50i to 24p. I understand that DVFilm maker will convert 50i to 25p, and a ~3% slowdown is then require for 25p to 24p. Is there any software used specifically to do the slowdown, or should just any NLE do it?
Ari
Ari Shomair is offline   Reply With Quote
Old May 12th, 2005, 07:56 PM   #2
i know fcp can do the slow down. just click on the clip, hit apple-j (for us mac users) and then type in 97% in the window that pops up. should be all thats necissary.
--Devereaux
http://geocities.com/anarchist_lb
Jon Laing is offline   Reply With Quote
Old May 12th, 2005, 08:54 PM   #3
I'm not an apple user unfortunately :( Any PC solutions?
Old May 12th, 2005, 09:26 PM   #4
Magic Bullet
Leigh Wanstead is offline   Reply With Quote
Old May 13th, 2005, 01:09 PM   #5
Ari,
Everything I read, on this forum and elsewhere says just convert to 25p, and use that for PAL DVD or broadcast. You only need to go to 24p is you are doing a filmout, in which case the filmout lab will want your 25p footage, and will slow it down for you.
If you want to do it yourself, I believe After Effects will allow you to interpret the 25p footage as 24p, adjust the audio speed, and output 24p.
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old May 14th, 2005, 06:04 AM   #6
Joshua is correct.
You do not need any software to "do the slowdown". You simply interpret the footage as 24p, which inherently makes it run around 4% slower on screen. This difference is not noticable. The audio is what needs processing to adjust for the change in pitch as it is played back 4% slower to match - I use SoundForge, but any decent wave editor will do you.
Dominic Jones is offline   Reply With Quote
Old May 16th, 2005, 04:42 PM   #7
DVFilm's Atlantis is probably the best choice: http://www.dvfilm.com/atlantis/index.htm
Canopus Procoder does a pretty decent job as well.
There is also Nattress Standards Conversion for FCP.
John McManimie is offline   Reply With Quote
Old May 16th, 2005, 04:58 PM   #8
I tried out DVFilm Atlantis - it can't convert 50i to 24p as far as I could tell.
Old May 16th, 2005, 05:21 PM   #9
Atlantis won't directly convert 50i to 24p, but it will convert 50i to "film-motion" 60i. That's 24p embedded in 60i. You can use DVFilm Maker to then extract the 24p from the 60i. It's a couple of steps, but it will probably get you where you want to be.
Josh
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
