Film Crew Position Descriptions at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 2nd, 2005, 05:51 PM   #1
Greetings!
I'm looking for a comprehensive, authoritative set of position descriptions for film crews, whether it be for full-length features, shorts, or documentaries and regardless of media (film or video).
Does such an animal exist?
I have found one source which looks good, and is a good example of what I'm looking for. I'm just not sure how authoritative it is. It is the Film Crew entry for wikipedia.org.
What I would like to do is start with the full blown set of positions for a major studio, and then map these positions into a much smaller set that a IFM or small independent studio might use.
TIA for your help.
Best Regards,
Pete
Pete Wilie is offline   Reply With Quote
Old May 2nd, 2005, 11:06 PM   #2
What's there is factually accurate but perhaps a bit too concise as far as the descriptions go to be useful to someone who's never worked on a fully-crewed production before. (For example, "assistant to gaffer," while not at all inaccurate, is a too-abbreviated job description for a Best Boy; under line producer it says "on schedule and within budget"--but this is a gross generalization, and one that is redundant of the producer's task, and moreover, should be the outstanding priority for every member of the cast and crew; etc.) The lists themselves are also fairly limited, omitting a number of important production positions and dozens of post-production specialists that your film may or may not require depending on the specifics and complexity of the challenges you'll be giving your film.
The IMDb's glossary is also good.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
