To De-Interlace Or Not To De-Interlace... at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old October 6th, 2002, 04:11 PM   #1
kino-eye
Posts: n/a
Try this as a budget alternative?
http://www.dvfilm.com/maker/index.htm
It has both version for PC and Mac. Good luck.
Old October 7th, 2002, 03:09 AM   #2
Slash Rules!
I'll give this one a shot and hope no one chastises me. You're asking if it's better to shoot in a camera's progressive (or pseudo-progressive) scan mode, or shoot in regular 60i and then deinterlace in post, correct?
According to the site you mentioned, shooting in, for example, the XL1s's frame mode will give you a lower resolution image. When panning or tilting in frame mode, in addition, I've noticed a really jerky effect once you start to pan/tilt past a certain speed.
In theory, and this is according to that site. . .recording in 60i and deinterlacing in post will give you a higher resolution image and eliminate this jerkiness, while still giving you the look that frame mode gives you. Haven't tried it myself yet.
Old October 11th, 2002, 12:35 AM   #3
Outer Circle
I thought it was the other way around, but then again, it depends on the cam.
Frank Granovski is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
