Deinterlacing - Page 5 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old April 21st, 2005, 12:08 PM   #61
Originally Posted by Patrick Jenkins
Well.. DV isn't lossless so there's degeneration to worry about, but also, won't saving as DV effectively reinterlace your material - at the very least bring back fields? Also, NTSC DV is stuck w/ 29.97 (or there abouts) frame rate, so inorder to save the 23.976 you'd have to do some sort of pull down (or something) - but I'm still trying to figure this process out.
Wouldn't it be all around better to use a final file format that's progressive and lossless (I've got Huffy, I'll experiement with that)?
All comes back down to, what is your final product? Are you putting the video on the web, archiving your work, or putting onto DVD? DV isn't stuck at 29.976, just 720x480. I've made plenty of 18fps and 23.976 DV files.
HUFFYUV and Lagarith (which is basically HUFFYUV but tweaked, you get much smaller file sizes) are great for archiving, but they will take up alot of room.
Kyle Edwards is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
