Deinterlacing - Page 4 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old April 11th, 2005, 06:53 PM   #46
Here is another script you might want to give a try. It converts 60i to 24p. I doesn't do any other filtering, just 60i to 24p.
Copy the following function between the dotted lines in notepad and save it as "convert60ito24p.avsi" in your Avisynth 2.5\plugin directory. Make sure you save it as an AVSI and not an AVS file.
function convert60ito24p (clip video, int mode, int offset)
work = assumefieldbased(video)
out =(mode==3) ? interleave(
\selectevery(
\layer(trim(work, 1, 0),
\layer(work, trim(work, 2, 0), "fast"),
\"fast"), 5, 0 + offset),
\selectevery(
\layer(
\layer(work, trim(work, 3, 0),"fast"),
\layer(trim(work, 2, 0), trim(work, 1, 0),"fast"),
\level = 170), 5, 2 + offset)) :
\ (mode==2) ? interleave(
\selectevery(
\selectevery(
\layer(work, trim(work, 1, 0), "fast"), 5, 3 + offset)) :
\ (mode==1) ? interleave(
\selectevery(trim(work, 1, 0), 5, 0 + offset),
\selectevery(layer(work, trim(work, 1, 0), "fast"), 5, 3 + offset)) :
\ (mode==0) ? selectevery(work, 5, 1 + offset, 4 + offset) : work
assumeframebased(out)
Now copy the following AVS file to notepad and change the 3rd line to whatever the filename of your AVI you want to convert. Save it as "convert60ito24p.avs" anywhere you want. This assumes your video is bottom field first, RBG24.
Import("C:\Program Files\AviSynth 2.5\plugins\convert60ito24p.avsi")
loadplugin("C:\Program Files\AviSynth 2.5\plugins\dgbob.dll")
AVISource("C:\YourVideoHere.avi")
AssumeBFF()
ConvertToYUY2(interlaced=true)
dgbob(0)
convert60ito24p(2,0)
ConvertToRGB24(interlaced=false)
Now open Virtualdub, from the file menu choose "open video file" and open the above AVS file. Once it loads, from the file menu choose "save as AVI" and your done.
Rokta Bija is offline   Reply With Quote
Old April 11th, 2005, 07:01 PM   #47
Speaking of comparing videos, here's a script that will show your before and after video side by side and show the difference below.
Copy the follwing between dotted lines to notepad, put your orignal video name and location in the line starting with v1, and modified video in v2. Save as BeforeandAfter.avs Open with Virtualdub.
# If Videos start at different frames
frameadjust=0
# Videos to compare: (v1 is original, v2 is encoded or whatever)
v1 = AviSource("C:\Original.avi").trim(frameadjust,0)
v2 = AviSource("C:\Modified.avi")
sub = v1.subtract(v2)
substrong = sub.levels(122,1,132,0,255)
return StackVertical(StackHorizontal(v1.subtitle("original"),v2.subtitle("encoded")),StackHorizontal(sub.su btitle("Difference"),substrong.subtitle("Difference amplified")))
The last line 'amplified")))' is supposed to be on the end of the line above it
Old April 11th, 2005, 10:57 PM   #48
That convert60ito24p script also has the benefit of being way way way faster than the equivilent MV Tools version. On my 1.6 Ghz Athlon, the MVTools convert only does a frame about every 45 seconds -- but switching out DGBob and Rokta's converter, I can run 4-5 frames per second -- roughly a 10x speed increase.
Depending on the source, it can be good enough for final quality. And if not -- you can use it for proofing and run the MV version overnight once you've got everything right.
Haven't tried the difference function yet... that one's next!
http://www.aqua-web.com
Jonathon Wilson is offline   Reply With Quote
Old April 12th, 2005, 08:52 PM   #49
function merge(clip a,clip b,float "opacity"){
opacity=default(opacity,0.5)
return a.MergeLuma(b,opacity).MergeChroma(b,opacity)
\selectevery(
\merge(trim(work, 1, 0),
\merge(work, trim(work, 2, 0))
\), 5, 0 + offset),
\selectevery(
\merge(
\merge(work, trim(work, 3, 0)),
\merge(trim(work, 2, 0), trim(work, 1, 0)),
\selectevery(
\), 5, 0 + offset),
\selectevery(
\merge(work, trim(work, 1, 0)), 5, 3 + offset)) :
\selectevery(merge(work, trim(work, 1, 0)), 5, 3 + offset)) :
That is the function I use. It runs a lot faster then the version above. The reason being is because they are using "layer". With that you MUST be in the YUY2 color space. With this you can easily be in the YV12 as well as other multiple color spaces as well as a big increase in speed.
I would also recommend using TDeint() instead of dgbob(). dgbob() does yield fair quality, but TDeint() blows it away by far. And if you have the time to render use MVBob(). That uses motion compensated deinterlacing methods to reconstruct a progressive frame from an interlaced frame. Then use either this method or use the function mv60ito24p(). If you use MVBob() with mv60ito24p() you will get the BEST quality possible (only if you can stand the rendering time).
Regards,
Josh
Josh Barker is offline   Reply With Quote
Old April 12th, 2005, 10:47 PM   #50
MvBob!!!
Unbelievable! I've never tried MVBob before... it is simply heads and tails above all the others. It almost seems to 'restore' progressive resolution (not possible, but it almost looks like it). Plus -- it's not all _that_ slow... I was seeing several frames per second (3 maybe) on full DV source material. I can live with that for these results!
Thanks for the kick, Josh -- that was definitely worth trying out! I doubt I'll use anything else, now.
Old April 13th, 2005, 12:41 PM   #51
hey josh what are the AVSI and AVS scripts for the mvbob method you talk about? thanks
Riley Harmon is offline   Reply With Quote
Old April 13th, 2005, 01:55 PM   #52
I lurk around the Doom9 forums at http://forum.doom9.org/ in the AviSynth forum. You can find MVBob() there. Here is a direct link to the page which gives you all the filters you need to get MVBob() to work:
http://forum.doom9.org/showthread.php?threadid=84725&perpage=20&highlight=mvbob&pagenumber=4#post606487
@ Jonathon Wilson: Glad you like the results! I do too :-), it is probably the best deinterlacer there is. Usually one such as this one (motion-compensated) is used in television series and anything that is being converted to the big-screen. And it usually costs MEGA $$$ and is done by hardware. We now have a nice software version (little slower, but it works wonders!).
Old April 13th, 2005, 02:13 PM   #53
MVBob link
The thread is long with many different iterating versions of the script. However well into the thread, there is a link to an archive containing the finished script and all the plugins needed. You can get it at the following:
http://home.arcor.de/scharfis_brain/mvbob/mvbob.rar
At least for now. Riley, what I did was unrar this whole thing into a directory of its own (something like c:/avisynthwork/mvbob).
Then I added an include at the top of my avisynth script which just includes the mvbob script from that directory:
include("c:/avisynthwork/mvbob/mvbob.avs")
This loads up all the right versions of the plugins etc. (at least it did for me...)
Then you can just:
fixed = src.mvbob()
easy peasy.
Old April 13th, 2005, 03:24 PM   #54
Jonathon, are you getting 3fps at 60ito60p or 60ito30p?
I get 3fps if I leave it at 59.94p but I'm only getting 1-2fps with MVbob for 60ito30p. From 60ito24p I'm getting less than .05fps (15 sec per frame) using mv60ito24p in default mode, and .5fps in mode3. Painful !
Josh, are you using the default settings with mvbob or? Also are you using the mvfps function inside the mv60ito24p in your AVS?
Here is what I am using. See anything that would cause the slowdown?
import("C:\Program Files\AviSynth 2.5\filters\MVBOB\mvbob.avs")
import("C:\Program Files\AviSynth 2.5\filters\MVbob\mv60ito24p.avs")
AVISource("f:\test7\4months - Clip 001.avi")
assumebff()
ConvertToYV12(interlaced=true)
mvbob()
mv60ito24p(mode=3)
ConvertToRGB24()
Old April 13th, 2005, 06:11 PM   #55
I am using mode 2 for mv60ito24p(). I have a hefty computer (3.2 Ghz HT, 1 GB RAM) and rendering is around 1-3 fps. HT is enabled and I've heard (since AviSynth doesn't support dual processors) it may be faster when disabled (haven't tested it yet).
Script I am using:
LoadPlugin("J:\Program Files\AviSynth 2.5\oldplugins\LoadPluginEx2.dll")
LoadPlugin("J:\Program Files\AviSynth 2.5\oldplugins\warpsharp.dll")
ImportPlugin("mvbob.avs")
AVISource("G:\Final Drunk Driving 1.avi",fourCC="CDVC")
TrimTime("00:21:00:00","00:21:20:00") #trimtime function by me
FixBrokenChromaUpsampling() #fixes bug in dv codec
ReInterpolate411() #ntsc capture bug fix
AspectRatio().AddBorders(0,1,0,2) #4:3 to 16:9
AssumeTFF() #not assumebff, I added borders so it shifted to tff
converttoyv12(interlaced=true)
MVBob() #deinterlace
mv60ito24p(2) #60p to 24p
ColorYuv(levels="TV->PC") #fix colors
Levels(10,1.0,255,0,255)
LimitedSharpen(overshoot=7,strength=100) #sharpen the picture
AddBorders(0,37,0,36) #letterbox 16:9
AddAudio() #add fake audio due to dv type-I, I use
ConvertToRGB().GiCoCU("J:\link2\s-curve.amp",photoshop=true) #apply film gamma s-curve
ConvertToYUY2() #not necessary if converting to mpeg-2
You may also increase in speed with mv60ito24p() if you use the following instead of the one you downloaded (I modified it to actually increase the speed):
function mv60ito24p(clip x, int "mode")
mode = default(mode,2)
mbl=0.1
fwd=mvtools0962_mvanalyse(x,isb=false,lambda=4000)
bwd=mvtools0962_mvanalyse(x,isb=true, lambda=4000)
y=x.mvtools0962_mvinterpolate(bwd, fwd, nb = 4,bl = 0.5-mbl, el = 0.5+mbl, wf = "uniform")
interleave(y,x)
mode0=selectevery(5,2)
mode1=merge(selectevery(5,3),selectevery(5,2),opacity=0.5)
mode2=merge(merge(selectevery(5,1),selectevery(5,3),opacity=0.5),selectevery(5,2),opacity=0.3)
mode3=merge(merge(selectevery(5,0),selectevery(5,3),opacity=0.5),merge(selectevery(5,1),selectevery( 5,2),opacity=0.5),opacity=0.5)
(mode==0) ? mode0 : (mode==1) ? mode1 : (mode==2) ? mode2 : mode3
Old April 15th, 2005, 06:33 PM   #56
I tired the modified mv60ito24p and it is faster, thanks. I also put the mvbob() function inside the AVS instead of importing it and that picked up speed also.
In the Avisource line, are you forcing a different codec with the fourcc command?
I had not used the overshoot parameter in LimitedSharpen, I liked the result. When I tried some other numbers, I didn't notice much difference from 7.
What do these two lines do:
Am I correct in thinking the ColorYuv(levels="TV->PC") scales a 16-235 to 0-255? And what is levels() doing?
Old April 20th, 2005, 08:53 PM   #57
What's a good format to save the final 24P to (I'm assuming a lossless, progressive format)?
Patrick Jenkins is offline   Reply With Quote
Old April 20th, 2005, 10:41 PM   #58
Encode to your final product straight from the script. If not, try HUFFYUV or Lagarith, both lossless. Or, why not DV again?
Kyle Edwards is offline   Reply With Quote
Old April 21st, 2005, 10:18 AM   #59
Well.. DV isn't lossless so there's degeneration to worry about, but also, won't saving as DV effectively reinterlace your material - at the very least bring back fields? Also, NTSC DV is stuck w/ 29.97 (or there abouts) frame rate, so inorder to save the 23.976 you'd have to do some sort of pull down (or something) - but I'm still trying to figure this process out.
Wouldn't it be all around better to use a final file format that's progressive and lossless (I've got Huffy, I'll experiement with that)?
Old April 21st, 2005, 10:58 AM   #60
HuffYUV is a good choice. It's what I use, too! (But the files are BBBIIIIIIIGGGG)
Kin Kwan is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
