ND at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old August 3rd, 2004, 08:20 AM   #1
Nd
What is ND???
Ken Anderson is offline   Reply With Quote
Old August 3rd, 2004, 08:43 AM   #2
Neutral Density
Cutīs off the amount of light coming in, without colouring the light.
Someone else might jump and give the proper definition in proper english.
Messenger Boy : The Thessalonian you're fighting, he's the biggest man I've ever seen. I wouldn't want to fight him.
Achilles : That is why no one will remember your name.
Federico Dib is offline   Reply With Quote
Old August 3rd, 2004, 08:48 AM   #3
ND
Thanks for the help, I'm new to this.
Ken
Old August 8th, 2004, 08:35 AM   #4
Ken,
Neutral Density filters, which come in different grades (0.1; 0.2; or, 1/4; 1/2; etc.), are used to cut down the light that is entering the lens. There fore, you can adjust the depth of field, without changing your camera speed:
Less light into the camera, the more you have to go to an f stop that provides a shallower depth of field. Such as from f8 to perhaps f5.6, or, f4.
Many times, such as when I shoot in high mountain areas, my XL-1s will notify me via the view finder, that there is too much light. I therefore switch in the built in ND filter.
In studio, it is an excelent way to separate the subject from the back ground with the afore said shallower depth of field.
As Federico mentioned, they do not change the colour's entering your lens, just the amount of light.
I hope this short note is of some use to you.
Himself
Robert J. Wolff is offline   Reply With Quote
Old August 9th, 2004, 11:58 AM   #5
Ken
IF you get an ND Filter (aside form the one in-camera...) get a GRADUATED ND. You'll be gald you did!
John Hudson is offline   Reply With Quote
Old September 12th, 2004, 05:05 PM   #6
John, do you know if the Nikon 52Mm Filter Nd4S is graduated? Can't seem to find out.
www.irishfilmmaker.com
Graham Jones is offline   Reply With Quote
Old September 14th, 2004, 06:01 AM   #7
RED Code Chef
I liked the description that ND is "sunglasses for your camera"
(ie, it lowers the amount of light entering your camera for all sorts
of reasons (using sweat spot of your lens, decrease Depth of Field etc.)
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
