Simple Framerate question at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 18th, 2009, 11:42 AM   #1
I use ULead Video Studio 11 and when you output your project to file or DVD you have a framerate option (23.**, 24, 29.**, 30, 59.**, and 60 fps) and then a Field option...(Top field, Lower Field and Frame Based)
Here is where I need some help...If I shoot in 60i and want to keep it that way all the way through I would save with a 59.** frame rate and a Lower Field option...
If I am right on that...and that's a big if, here is my question.
Can I shoot in 60i and then make that Progressive by simply saving my file as 59.** with the Frame Based option?
I like the look of the Frame Based option but don't like the lack of frames in 24p and even 30p...if I could get those 60 frames and turn it Progressive, that would be ideal...
Luke Neumann is offline   Reply With Quote
Old May 21st, 2009, 09:54 AM   #2
Wouldn't you convert 60i to 30p? If you convert it to 60p I would think it might create a jerky motion since each frame is repeated.
Steve LaPierre is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
