Cinema Lenses for DV at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 25th, 2004, 09:10 AM   #1
I have a DSR-390 Sony Camera, and I want to give it the closets look to film as possible, so is there any special kind of Cinema lens I can buy for this purpose? Or will the 19 inch Canon lens be enough for this purpose?
Hamad Abdulla is offline   Reply With Quote
Old January 26th, 2004, 09:08 PM   #2
So you are too going for the film look. Well if you are looking for more DOF then you should consider couple of these threads.
http://www.dvinfo.net/conf/showthrea...threadid=20408
http://www.dvinfo.net/conf/showthrea...threadid=17195
http://www.dvinfo.net/conf/showthrea...threadid=18690
Oh also there are 16 9 adapters you can buy for a normal lense. For this check out http://www.centuryoptics.com/products/dv/16x9/16x9.htm.
Note that those are not true wide screen.
There are other things you can do so look through the board.
Dmitri Henry is offline   Reply With Quote
Old January 27th, 2004, 03:16 PM   #3
RED Code Chef
The question has been asked a lot in this forum Hamad. Please
take a little time and look around.
The "film look" beings with a great story, good cinemetography
(lighting / framing etc.), acting, music etc.
A lens might help, but I would definitely make sure I have all
the basic gear first you will need much more. There is not a
magic one piece gear or piece of software.
Color correction in post can do wonders as well in my opinion.
Rob Lohman, visuar@iname.com
Old January 31st, 2004, 12:10 AM   #4
thanks a lot for all of your replies and help!!!
Old January 31st, 2004, 02:55 PM   #5
Sorry about my misunderstanding in fact 16:9 anamorphic lenses are true wide screen. From what i understand they squeeze the wide rectangular image into your regular squarish ccd. The way it works is by stretching the image vertically and squishing it horizontally. In the end you end up with no resolution loss (since you are using full vertical resolution) and a wide perspective.
Sorry for the false information i am still a newbie in dv.
Old February 3rd, 2004, 05:29 PM   #6
This is a great anamorphic adapter:
As stated previously, however, it all starts with a great story, and great technique.
Anthony Claudia is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
