ever use lens adapters from this company? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old November 30th, 2003, 11:52 PM   #1
Posting disabled - Contact Admin.
Hi there. Have any of you ever used products from virtualcybervision.com?
In particular, i'm wondering about the EOS adapter and the peleng fisheye lens adapter.
Anyone have any experiences with any products made by this company?
Any thoughts about these lens adapters?
AJ Briones is offline   Reply With Quote
Old December 1st, 2003, 12:40 AM   #2
Seens cool but you lose DOF with only adapting the lens to the XL1, its not the same than if you use Mini35, or my homemade lens adapter.
Agus Casse is offline   Reply With Quote
Old December 1st, 2003, 06:46 AM   #3
Warden
Search our site for XL1 Solutions. There are several current threads debating the merits of the adapter and it's manufactures claims. Don Berube is in the process of evaluating one of the adapters.
Jeff Donald
Carpe Diem
Old December 1st, 2003, 01:56 PM   #4
Barry Wan Kenobi
I used the Peleng fisheye on the DVX100 with the mini35, and the results were outlandishly cool.
Without something like the mini35, your results will be nowhere near as good. The stock lens on the XL1 is already wider than 8mm (I think it's 6mm or so) so adding the Peleng won't give you anything you don't already have. You need to use the mini35 (or similar) in order to get the equivalent 35mm field of view. Once you do that, then the 8mm has an outrageously wonderful fisheye effect.
Check out this picture, shot with the DVX/mini35/Peleng 8mm lens:
http://66.78.26.9/~fiercely/DVXvsJVC/DVXMini35-8mm.jpg
Barry Green is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
