Video vs. Film Lens
Hi all,
I've done a test over the weekend to determine if there is any advantage in using a photo lens on the Canon XL1. I used a 28mm Nikon with an F8 iris opening. I tried to match the shot size with the Canon 16X video lens @ F8 as well. I did not do any post color or contrast enhancement on either screen grabs. I would like to get everyone's opinion on the images. http://www.beinfinity.com/temp/jason/video.jpg http://www.beinfinity.com/temp/jason/film.jpg |
The one labeled video looks much better IMHO.
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
I seem to like the leaves in the background of the 'film' image better and the lady better in the 'video' image.
The 'video' appears to have a smoother look to it while the 'film has a bit more contrast. Have any more stills to post? BTW You can add [url ] before and [/url ] (withouth the space) after the address to hotlink it. So it's [url ]http://www.beinfinity.com/temp/jason/video.jpg[/url ] without the spaces inside of the brackets. http://www.beinfinity.com/temp/jason/video.jpg http://www.beinfinity.com/temp/jason/film.jpg Cheers, Huey |
I'm with Dylan, but the lighting is too poor to really get a good idea.
Adrian DVInfo.net Search for quick answers Where to buy? From the best in the business...DVInfo.net sponsors |
#5 |
I agree. The "film" lens has much better contrast and chromaticity. I would assume the video lens is cheaper or possibly a zoom?
#6 |
Hawaiian Shirt Mogul
i didn't look at the pic's ...
but lens made for 35mm do NOT have the resolution that lens made for 16mm ( 16 mm lens must resolve more lines then 35mm) .. the larger the format then less lines of resolution - if you look at lens made for 2 1/4 camera's the lens may have around 40 lines of resolution whilte 35mm may have around 60-70 ... 16mm 100 lines .. lens made for 4x5 camera only need around 20-25 lines of resolution ...the smaller the format the MORE lines of resolution required ... so for a 1/4 or 1/3 " CCD the lens should have a higher resoloving then 35mm lens ... also 35 lens are MADE to focus on a flat object they are not designed to go thru a beam splitter and sent to 3 different CCD's ... take a look at HD lens ( made for 2/3 " CCD's ) and you will see they have a higher resolving power then 35mm lens ... now all that is theory as you must take price into consideration on these hand size camera's ... and THEN again the 35mm/16mm/ 2/3" video lens are probably beyond what the NTSC signal can resolve anyway ?? so maybe that makes resolving power useless when comparing these lens ? on a NTSC video camera ?? |
