4:1:1 vs. 4:2:2 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old October 22nd, 2003, 08:47 PM   #1
4:1:1 vs. 4:2:2
Can anyone tell the difference between a video footage shot on a 4:1:1 format camera and a camera with a higher color sampling ratio?
Jason Chang is offline   Reply With Quote
Old October 22nd, 2003, 08:56 PM   #2
Great DV dot com
Yes. If your eyes are trained and you know what you're looking for, you can see it. It shows up clearly in certain situations where sharp color shifts are needed.
It shows up worst in chrom keying, of course, but there are now good solutions for that.
The average eye will not be able to see the difference, but there are post processing situations that will accentuate the problems.
John Jackman
www.johnjackman.com
John Jackman is offline   Reply With Quote
Old October 22nd, 2003, 09:15 PM   #3
Warden
The term 4:2:2 refers to the ratio between the number of samples of the luminance channel (4 samples) and the chrominance channels (2 samples each). So for every 4 luminance samples each color channel is sampled twice. 4:2:2 would have twice the color bandwidth or detail as 4:1:1
Jeff Donald
Carpe Diem
Old October 23rd, 2003, 07:12 AM   #4
Thanks for taking the time!
Old October 23rd, 2003, 07:25 AM   #5
I think the difference you will see will actually come from the fact that any camera that output 4:2:2 is of much higher quality than a standard consumer dv camera. So yes everything jumps in quality.
Zac
Zac Stein is offline   Reply With Quote
Old October 23rd, 2003, 10:28 AM   #6
Barry Wan Kenobi
You can answer this one for yourself, if you get a chance to demo the Panasonic SDX900. It's switchable between 4:1:1 and 4:2:2, so you can see the exact same camera/lens combo used to record both formats, and then judge whether you think there's a difference...
Old October 25th, 2003, 09:58 AM   #7
Thank you for taking the time to help me out!
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
