Burning a wooden shack in the forest? - Page 2 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old March 19th, 2009, 02:47 PM   #16
I've only used black screens for that type of keying (Smoke and fire) and it's pretty easy, especially since you can use a blending mode in 1 second instead of taking the time to key it. I've always assumed a green screen wouldn't work as well.
I'd use a black model resembling the shack to set on fire, and superimpose that video on the real shack. That could be done pretty quickly too, so it would be worth trying even if you do end up building a miniature replica.
Aric Mannion is offline   Reply With Quote
Old April 5th, 2009, 05:07 PM   #17
Just on the cg side of things. Maya has built in fire samples. They are ok, but if its a daylight scene the fire wouldnt look so good.
The best cg fire at the moment that isnt proprietary software is probably fume fx.
FumeFX fireball on Vimeo
fumefx flame test on Vimeo
FumeFX burning wood log - HD on Vimeo
I think the black screen compositing method is used a lot in professional fx. You can also get stock clips of fire and smoke form online sites for this purpose.
Kelly Goden is offline   Reply With Quote
Old April 5th, 2009, 05:52 PM   #18
I'll put in a second for FumeFX, but it's not easy and you need 3ds max for it. Check out the 'sample A' from this training DVD:
ALLAN MCKAY - FUME FX ADVANCED DVD
David Petersen is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
