#16 |
Re: What Gear does Everyone use to Broadcast
I use a C100 and a Vidiu Pro. The Vidiu app is very buggy for me, but the unit works well though a web browser.
My backup is a Macbook Pro running OBS connected through a Black Magic Mini Recorder. Last edited by Kevin Walsh; September 5th, 2016 at 05:59 PM. Reason: Spelling |
#17 |
I've done a few things at work, mostly testing, but we've done a handful of events
We have a Matrox Monarch and have had a few different hdmi cameras into it, nothing particularly fancy though. I've also played around with OBS with various USB cameras - webcams and higher end Vaddio and Logitech PTZ cameras. OBS is getting pretty neat. OBS Studio seems to be getting there as far as usefulness goes Generally we've tested streaming out to youtube, or locally with the matrox to VLC for overflow rooms The advantage I have at work is we have really good internet, unlike the rest of the country. I'm really interested in trying my hand at streaming more. What do most Aussies do for streaming? Do you rely on 4g data, with most locations access to internet means ADSL with crappy upload speeds? Also, do you have multiple connections with different telecos, go with one particular network, or have you worked out a way to do something along the line of bonded networking without forking out a looooot of money? |
#18 |
Equal Opportunity Offender
Book an event at a hotel or other venue which already has a very nice amount of bandwidth. :-)
Andrew |
#19 |
Hi Matthew
Unless they are on the NBN, any venue with ADSL2 still has a physical upload limit of 1mbps upload so unless you are happy with a poor quality 480P that will only be looked at on a phone You really need an upload connection 50% higher than the speed you want to broadcast and 500kbps isn't exactly great. If you are using a venue be sure to do a test a week before so you know it's a dedicated connection and it will work on the day!! We use a 4GX wifi modem and get a minimum of 10mbps upload from Telstra so we can safely stream out HD at anything up to 5 or 6 mbps with no issues. However it IS more expensive than using a venue's connection as long as there are no tech issues as most venues have offsite tech support. Our 4G costs us $10 per GB which we simply add to our package costs. We also have an antenna stand which elevates the Omni MIMO antenna unit and does help matters in rural areas. Our Livestream Studio software or even our simple Broadcaster Pro units also can be setup for bonding at no extra cost apart from a 2nd wifi unit |
#20 |
Used the ATEM Television studio and now the Datavideo HS-1200. Mix in 3 or 4 cameras (Canon XF-305) and do graphics and such. This is usually steamed out via Wirecast but sometimes a hardware encoder. Do ~150 live events a year. i stream between my own servers running Wowza and onto the Highwinds CDN when needed.
Simple Thought Productions - Life @ 30,000 Words per second |
#21 |
Thanks Josh
WOW 150 events a year!!! What do you broadcast mainly? |
#22 |
Yippee livestreaming straight to YouTube with only x70 and my new Galaxy s7. I am using two apps. Screen Stream Mirroring. And Internal audio. Unfortunately I had to root (Jailbreak) my new phone to get the audio working. That was simple to do following tutorials but I will have lost my warranty. Now I just need to figure out how to share the livestreaming using just the phone. It's simple to do on the phone but not so obvious on the phone.
#23 | |
Events like the one in the demo here: http://www.simplethoughtproductions....deo-streaming/
Simple Thought Productions - Life @ 30,000 Words per second Last edited by Josh Chesarek; September 24th, 2016 at 06:33 AM. |
#24 | |
I work at a Uni, so internet on campus is crazy fast compared to anywhere else, which is pretty handy for the few times we have done streaming at work. I guess if one 4g connection has enough bandwidth for HD streaming, bonding is less necessary for speed, but the ability to have multiple connections for redundancy purposes would be handy |
#25 |
It might be obvious, but setting up and streaming from the JVC LS300 is quite strait forward.
Some struggle with setting the combination of format details is the only I have experienced. It is though my private streams and I have not experienced any YT sensuring in my small trials. Quality --I have not yet done enough for any judgement. Streaming is done 1080/50i from a 25p setting. 720 is adviced - I will try that later - hopefully directly through my iPhone, eventually a 4g router. FB on the other hand requires a page to get access to the publication tools, as I understand it : "Create a Page Give your brand, business or cause a voice on Facebook and connect with the people who matter to you. It's free to set up. Just choose a Page type to get started." Since I am not a pro - the need for this is limited at the moment. |
