Thread Tools
Search this Thread
which canon prime's have manual aperture?
I'm trying to figure out which (if any) of canon's EF series lenses have a manually adjustable f-stop or if they're all done through teh camera. Any help would be awesome.
thanks
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome... |
Hi Nick,
I don't know if this helps, but a quick look at the Canon website seems to confirm, that none of the currently available EF lenses has an aperture ring. I can confirm however, that the following lenses don't have a manually adjustable f-stop (may be this narrows down your choices already): EF 24-70mm/2.8 L USM EF 24-105mm/4.0 L IS USM EF 70-200mm/2.8 L IS USM EF 100-400mm 4.5-5.6 L IS USM EF 300mm/2.8 L IS USM EF 500mm/4.0 L IS USM EF 100mm/2.8 Macro USM If you really need the manually adjustable f-stop you should perhaps look for some FD lenses. There are FD to EF adaptors available so you can use them on EOS bodies (no AF of course).
Keep rolling Rainer |
Rainer, thank you very much, that was kind of what I was afraid was the case. I'll look into the FD lens options though.
#4 | |
none of the EF compatible lenses have manual apertures. Forget about FD as the only way to use FD is with two different types of adapters. One is a cheapo $40 adapter that has no optics and acts like an extension tube and you loose the ability to focus to infinity The other is an expensive canon made adapter that has a little teleconverter built in that allows you to focus to infinity but is also a 1.2 or so tele converter. Biggest problem is to find one and if you do they run about $500 as they are collectors items by now But there are easier solutions. You can use manual nikon lenses with a cheap adapter on any canon EF body. Get the adapter Nikon to EOS and then buy any cheap manual focus nikon lenses and enjoy. You can do the same thing with almost any other lens including zeiss glass, minolta manual glass, ... BTW the movie corpse bride was shot this way utilizing Canon 1DMarkII cameras with manual nikkor lenses using adapters.
Michael Salzlechner |
