glidecam 2000pro vs 4000pro
I'm about to buy a glidecam but was wondering if the 4000 can ballance cameras less than 4 pounds very good or not. I'm will usually be using a vx2000 and big battery. Occasionally some wide angle lenses. Just wondering what your all's experiences have been. Would I be better off with the 2000 or 4000?
Thank you all for any replies. |
Are you going to use just a 2000/4000 pro alone or match them with a smooth shooter system?
I had the 2000 when I owned a gl2. It worked ok. I could get the same results using my monopod or even a folded up tripod. IMO, I don't think they are worth the money. Your arms will hurt after using one for only a few minutes which makes them very unpractical. I couldn't imagine holding a 4000 with a vx2000 attached. |
just going to use it alone.
Thank you for the advice. |
Eric,
The 4000 is generally for the larger cameras and the VX2000 is sort of in that range. I would guess it would work fine as long as you can get a good drop time balance. This might mean messing with the bottom-plate weights but it isn't that hard to do. I believe you could balance your camera on either the 2000 or 4000. The question is if you are thinking of getting a larger or smaller camera in the future and will you be adding extras like a wireless mic set-up etc. Smooth Shooting, Terry Indicam |
#5 |
The big six
Hi Eric,
The Glidecam 4000 is for cameras more than 6 pounds in weight. I'd guess you could balance a lighter camera with the GC 2000, or if worse came to worse you could always add a few pounds to the camera. I'm sure we must have some of our users who have light/heavy cameras that would get the GC 4000 to handle both. Regards, Michael |
#6 |
Thanks for all your responses guys, I ordered the 2000 yesterday and will let you all know how it works with the 2000 in various set ups.
