Rebalance your Merlin
Just a short tale of my experience with balancing the Merlin.
When I got my Merlin back in April this year I took quite a bit of time getting the balance correct. Because of the time needed (I knew it would take time) when I got the balance correct I was so happy I then went out to start practicing....... Although I had it balanced I kept getting small problems with yaw etc. Then one day I noticed a fault in my Merlin. I returned it the USA and Tiffen. It was soon back - fixed under guarantee. I rebalanced, this time using the "Exel" spreadsheet on the Tiffen site. I got it balanced - noticing that this time I had entirely different weights and arc-size than before. But it seemed to be easier to control than before. After exchanging an email with Mikko, I changed the settings for a 3rd time. Now the Merlin is perfectly balanced - with little or no side-effects. The moral of my story is: After wrestling with the initial balancing for a few hours and finding what you think is the correct setting - note them - then try again with other settings. It is quite possible that your initial settings were not as perfect as you thought. Hope this makes sense to you! Douglas
I was produced in Scotland, edited in Sweden, and am now showing in Japan. http://www.gaijin-eyes.com |
What cam are you using? What is your drop time?
I had exactly the same problem with my merlin. I was balancing too much to the eye and that is what caused me problems
