#91 |
Depends on the rig. The Smooth Shooter doesn't have any adjustment but the larger Glidecams do, as does the Tiffen Flyer. The adjustments set the attitude of the arm relative to the operator; fore-aft and left-right. This allows the arm to always fly level (i.e. not pull away to one side or away from the operator) when the operator is standing comfortably. Obviously a skinny guy and a big-bellied gent will have a different pitch to the part of their body where the arm attaches to the vest, so you can imagine why this is a necessary adjustment to be able to make, otherwise you have to compensate by leaning your body to counter the rig, or as I said most will use force to reign in the arm.
The knocking noise I wouldn't have an answer for you on, other than if it shows up in the footage, it may well be what you are thinking, otherwise it could be the spring shifting around in its mount.
Charles Papert www.charlespapert.com |
#92 |
Thanks, Charles.
How do the adjustments work? The only thing I can think of is that the fore-aft and left-right adjustments change the angle that the arm comes out of the vest... at the socket block? fore-aft <-> tilt angle of arm up or down left-right <-> bend angle of arm left or right Is this correct? I've never seen a professional "big rig" up close in person or in pictures so I have no idea. |
#93 | |
Indicam review continued
First, Terry's gizmo is an extrordanary piece of machinery. Hands-down the best bang for one's buck. I tried a Glidecam4000, not even close. Second, who in his (or her) right mind would build the reverse of many years of development? Unless customer service was important. I've been to Terry's shop, and seen his protype bin! (Yikes!) Finally, Terry's quality control is pretty phenominal. the gimbal is a work of art. I did buy the "Goofy" rig Terry was grappling with, why??? Because I use DVX100 cameras and the monitor is not as high as the new Sony and now the camera flies off-center to the right! Perfect monitor placement. I also have little experience with stabilizers, so there's no re-inventing any wheels. I found the reversed setup a pleasure. 10 minuites out of the bag to flying. Being right-handed is not a handicap, I find I have a lighter touch and actually rememer to let the sled fly hands-free. (Which it does easily) I have a feeling everyone (newbies like me) will want their rig "Goofy"! Rusty |
