Handheld Stabilizer Users... How do you reduce forearm and back fatigue? - Page 3 at DVinfo.net
Old May 12th, 2006, 08:21 PM   #31
Originally Posted by Terry Thompson
I have finally uploaded a clip from the last wedding. Boy what a week!
It can be found here:
www.indicam.com/media/steadiweddingSlow.wmv
Some of the best shots are lock-offs which I can also do with my rig.
Be kind as I am a manufacturer and not a professional steadicam operator.
Thanks for sharing, Terry. I would have liked to see more shots but the two you showed were good.
When you say some of your best shots are lock-offs, are they lock-offs done with your rig, or tripod shots?
Also, do you get people giving you weird looks when you're in your rig? :)
I'd like to see the shot of your son muttering about his tiredness, if you have that, too ;) How long was he holding it for? Was he using the rig or just the sled?
Thanks again for sharing, Terry!
Peter Chung is offline   Reply With Quote
Old February 6th, 2007, 03:44 PM   #32
Hi.
I also have a nice Glidecam 2000 clip in wedding situation.
This is a mix with several weddings at photo time.
Hope you enjoy it :)
http://www.relaxvideo.hu/esk-videok.html
After 20-30 minute of using, my wrist is very fatigue, so i think to buy
a forearm brace. I'm only 28. But its quite expensive in Hungary.
Marton
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply With Quote
Old February 7th, 2007, 01:42 AM   #33
Hi Prech,
This might look a little weird, but a sling (like you'd use for a broken arm) has become my new favorite way to battle fatigue when holding a stabilizer.
Dan
www.DVcameraRigs.com
Dan Selakovich is offline   Reply With Quote
Old February 7th, 2007, 03:21 PM   #34
Dan,
That will indeed help while resting or doing static shots but you want to have your arm free to do some steadying during a moving shot. Otherwise you could just use the Glidecam Forearm Brace which does the same thing. It doesn't allow up and down stabilization but the sled will help smooth out the side-to-side jitter.
You probably already know that but just for the record...
Terry
Indicam
He's only mostly sDEADy.
sort of from "The Princess Bride"
www.indicam.com
Terry Thompson is offline   Reply With Quote
Old February 8th, 2007, 10:03 AM   #35
I think you'd be surprise how much "UP" movement you can do. but you're right: Down, not so much. For a "Walk and Talk" tightening the sling up and using a "burrito" (a sound blanket rolled up) stuck between your arm and body gets suprisingly smooth shots from a hand held. (I've also used a wrist splint which helps as well).
dan
Old February 8th, 2007, 11:02 AM   #36
Dan,
Great idea for an inexpensive arm support. It's not like a real stabilizer arm but it sounds like it would work somewhat. I suppose your wrist does much of the up-down stabilization.
Hey, Maybe you could have a "donations box" nearby because it might look like you have a broken arm.
Terry
Indicam
www.indicam.com
Old February 9th, 2007, 09:12 AM   #37
The local drug store thinks I'm really accident prone!
dan
