Everything you wanted to know about the Steadicam Merlin... - Page 9 at DVinfo.net
Old December 22nd, 2007, 12:17 PM   #121
Hi! Can someone explain me - what is the difference by adding this one weight in front? I am using Canon XHA1.
Ivan Mosny is offline   Reply With Quote
Old December 22nd, 2007, 06:58 PM   #122
I'm not 100% sure what you're asking, but if you're wondering about the purpose of the weight out in front, I believe it is to increase rotational inertia about the vertical axis through the center of gravity.
In other words, to eliminate some of the tendency for the whole unit to spin freely about the vertical axis
That's what I think it is, but I couls be wrong. Just my opinion.
Or I could be misunderstanding your question.
Old December 22nd, 2007, 11:16 PM   #123
Adding weights to the front (as opposed to the bottom) serves 2 purposes:
It does in deed ad greater horizntal inertia - making "pan" more stable.
It has a smaller effect on the drop time, and allows you to slightly more fine tune the drop time.
In addition, it also has an effect on dynamic balance - you need some (even just one start-weight) weight on there to be able to dynamically blance the sled properly.
But, yes, it's mostly to increase "pan" stability to match the allready huge "tilt" and "roll" stability of the Merlin.
- Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA
+1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com
Mikko Wilson is offline   Reply With Quote
Old December 23rd, 2007, 11:55 AM   #124
Thanks guys for the Answers. My new Merlin works fine, but i am still not sure to use this one "full weight" (in add to start weight) in front or not. I will trainig with both options.
(Sorry for my bad english)
Ivan
Old December 23rd, 2007, 12:04 PM   #125
Yup, try both options and see what works best!
Exprimenting is the best way to learn & understand Steadicam.
- Mikko
Old December 23rd, 2007, 03:59 PM   #126
Merlin works wonderfull. I have Flycam stabilizer with the Vest too - but i was never able to tune this thing so fine as a Merlin.
But where is the best place to mount my Manfrotto 521 LANC Steering? Merlins hangrip is too small. Is there a chance to change it for a bigger one?
Old January 12th, 2008, 11:33 AM   #127
Merlin Bobbing
Is a properly balanced Merlin rock steady when held or balanced on itself?
Mine just keeps every so slowly bobbing around like a boat on a calm lake. I just can't stop this movement. What's the deal?
The metal gimbal seems super sensative compared to the plastic one I tested.
Any suggestions?
Deniz Ahmet is offline   Reply With Quote
Old January 12th, 2008, 11:38 AM   #128
once balanced and steady it will reamin in place - it shouldn't move by itself.
That said, once you accelerate it (or slow it down, or turn a corner at speed), due to the dlight bottom heaviness, it will want to act very slightly like a pendulum .. so as an operator, it's your job to use your guide hand to very gentally counteract this swaying as you accelerate to prevent it from happening.
With practice you quickly learn what things will cause it to sway and how to prevent it.
- Mikko
Old February 21st, 2008, 02:54 PM   #129
Hi,
the side-to-side trim roller of my merlin is very hard to rotate. What can i do?
Ralph Schoberth is offline   Reply With Quote
Old February 21st, 2008, 02:59 PM   #130
Is the Merlin level as you try to rotate the roller? Try rolling the rig very slightly to the side so that the roller is moving the camera "down hill" so it's not having to move the weight of the sled up.
- Mikko
Old February 21st, 2008, 03:48 PM   #131
i mean the roller under the dovetail to adjust the left/right level.
Another question is: have the gimbal to be exactly under the center of gravity of the cam?
Old February 21st, 2008, 03:49 PM   #132
Yes, I know which roller you are referring to.
Is it hard to turn even if there isn't a camera on the Merlin?
And yes, you do want to get the gimbal directly under the CG of the camera.
- Mikko
Old February 21st, 2008, 06:11 PM   #133
boy this thread is choc full of good info - I solved 2 problems I didn't even know I had!
..now back to the cross on the wall..
Cheers - Paul M.
www.perbenyik.com
Old February 22nd, 2008, 12:10 AM   #134
- Mikko
Without camera ist easyer to turn, but not as easy as the for/back roller.
Any idea to get it smoother?
Old February 22nd, 2008, 05:58 AM   #135
It doesn't need to be super easy to turn - too loose and it might not hold balance as easily.
Try rolling it all the way to one side, and cleaning the underside of the stage beteen the side-to-side support rods. Then roll all the way to the other side and clean to other side. Try going too the way forwards and all teh wya back too, to get as much of the underisde of the stage cleaned as possible. - It's possible you have some dirt in there.
My side-to-side roller is also a little tighter than the fore-aft - and both are fairly stiff. I fyou can still adjust it without too mcuh teouble, then it's probably ok. Inly if the rollers are so tight that thye are actually preventing you from makign trib adjustments with your fingers, are they actually too tight.
- Mikko
