#31 |
Getting started
Hey Mikko,
You are a walking Merlin Encylopedia! Thanks for all the information. Taking both the Z1 and the HC-1 out for trial flights this week. Sorry I didn't run into you at NAB. Best Regards, Jack |
#32 |
With regard to the problem concerning the mounting screw on the Merlin, use a pinch ring. It will hold the screw in place, while allowing the screw to be tightened or loosened.
#33 |
what's a pinch ring?
And is that advice true of any screw? I have found that the screw that holds in place the little lever you turn to attach the camera to the merlin has been coming loose and making the whole thing not stay in place very well (and I found it hard to balance when everything stayed put). Would a pinch ring solve that problem. And if so can I just ask for one at Home Depot and have any hope of them handing me the right thing?
#34 |
For that, head over to the adhesives section of your Home Depot, and grab some Blue loctite. It's the nonpermenant stuff. The little ring is for keeping a screw attached to something while still letting it turn.
#35 | |
#36 |
One modification that I'd like to see would be the addition of a locator hole in the tripod adapter plate. All of my tripods have a locating pin in addition to the mounting screw for the camera. The Merlin tripod plate doesn't have that hole. Not a big deal since I'm about to add one myself, but I was a little surprised not to find one already there.
#37 |
To solve the screw problem mentioned above I bought another screw longer than the first and put two lock nuts on it. Now it does still turn to allow you to open and close the screw and I found that it makes the grip tighter two. I also put a plastic vice on to make sure it dosent slide up and down the platform. I think a little better thought should have been put into the grip screw as it seems poor craftmanship. Im sure a better solution could have been found and still not add wieght to the merlin. Also im surprised that they limit the wieght to only 5lbs as most pro consumer cameras will be just over this wieght. Is this to get out of the fact that pro consumer cameras will be used more than consumer cameras therefore forfitting the warrenty? With the price tag it is clearly aimed at the pro consumer market, as most people with a consumer camera wont want to buy a stabiliztion unit that costs more than there camera.
With all that said and done I think it has the protential to be a great product for low budget productions. |
#38 | |
Few "consumers" (i.e. casual camcorder users who mostly have cameras to cover family events, etc) will be able to get much use out of a mechanical stabilizer because the learning curve is likely beyond what they are interested in, the gear is too bulky to travel with and carry around, etc. I think it safer to say that the Merlin is aimed at the lower level of "prosumers" who are using the smaller class of cameras for one reason or another. In this case, it is true that the rig will possibly cost more than the camera, but of course it will likely outlast it in the same way that one can keep a good tripod for years while upgrading the cameras that going on it over time. The 5 lb+ class of cameras are more suited to the Flyer rig which incorporates the vest and arm to help manage this payload. Certainly it is much more expensive than the Merlin (once again the stabilizer is as much or more than the camera itself), but at this point both the camera and stabilizer can deliver such good results that the resulting footage can compete with that captured by a high-end camera/stabilizer combo that costs literally hundreds of times more.
Charles Papert www.charlespapert.com |
#39 | |
Merlin TRIPOD plate - some pictures
I have tried the tripod-mount during holiday and it works (you NEED it if you switch regularly between tripod and Merlin). Two remarks: 1) The tripod-mount has only one hole for the mounting screw, not for the locating pin of your tripod (I have no idea why). So you need to remove the locating pin of your tripod plate (and put it in your wallet or you'll lose it). (my tripod is a Sachtler DV 2 II). 2) Using the tripod-mount also requires that the camera is mounted to the mounting plate in such a way that the lcd-screen horizon is absolutely parallel to the horizon of the mounting-plate (some smaller camera's, like mine need some adjustment with a coin or tape or something), otherwise the camera will not be parallel to the pan-plane (don't know if this word is the correct word) and your filmed horizon will have a roll to left or right. This trimming you will need to do when the camera is mounted on the tripod (by the tripod-mount). I have posted some pictures to iilustrate this on: http://www.xs4all.nl/~mali99/Merlin%...od%20pictures/ Hopes this helps, Pieter |
#40 | |
I have tried the tripod-mount during holiday and it works (you NEED it if you switch regularly between tripod and Merlin). Two remarks: Using the tripod-mount also requires that the camera is mounted to the mounting plate in such a way that the lcd-screen horizon is absolutely parallel to the horizon of the mounting-plate (some smaller camera's, like mine need some adjustment with a coin or tape or something), otherwise the camera will not be parallel to the pan-plane (don't know if this word is the correct word) and your filmed horizon will have a roll to left or right. This trimming you will need to do when the camera is mounted on the tripod (by the tripod-mount). I have made some pictures to iilustrate this on: http://www.xs4all.nl/~mali99/Merlin%20tripod%20pictures Hopes this helps, Pieter |
#41 | ||
Thankfully all tirpod have either a removable or retractable locating pin. But yes I agree that here should be a 2nd hole there. Quote:
I'm not exactly sure what you mean here. Why do you need to roll the camera to one side? Is your camera's base not flat and level? - Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA +1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com |
#42 | |
The Merlin manual is mentioning this - more or less- in Chapter 5 "Installing the Dovetail Plate, Prepare your camera": it is recommended to put some thick Gaffer's Tape running fore and aft (but I did'nt have it when I first set it up, maybe I should follow up the advice now..). With professional camera's this probably is not an issue. Pieter |
#43 |
Ew yeah, that's not good.
Yeah, tape or a peice of thick cardboard under there woudl definatly be a good idea. Ugh, why do camera makes release shotty things like this? - Mikko
#44 | |||
#45 |
Merlin Vest
When is the vest for the Merlin coming out?
Nick |
