home built steadicam - Page 3 at DVinfo.net
Old April 9th, 2003, 12:35 AM   #31
Thanks Charles and Cosmin...I am on it!
Chris Simmons is offline   Reply With Quote
Old April 9th, 2003, 02:26 AM   #32
Cosmin,
Thanks for the pics. I have been browsing that site for sometime and find it very informative.
Just acouple questions:
1) Did you have access to a machine shop or did you buy the parts premade?
2) Are you able to adjust the tension in the springs?
3) It looks a little heavy. Did you need that thick of aluminum?
BTW- Love the short little video you did. LOL.
Rob:D
Robert Poulton is offline   Reply With Quote
Old April 9th, 2003, 03:55 AM   #33
"1) Did you have access to a machine shop or did you buy the parts premade?"
All the parts are custom made... I designed the parts but I don't have the tools and knoledge to do the work myself. Anyway I'm lucky to have some friends that helped me with this. So it costs me... nothing, compared to the real price for such work.
"2) Are you able to adjust the tension in the springs?"
Yes. You realy need this option. You can't calculate 100% the springs. So you need to be able to adjust them. Also, you might change something in the setup, in the future (like the camcorder...), that will alter the weight of the sled.
"3) It looks a little heavy. Did you need that thick of aluminum?"
It is quite heavy. :) I think is about 23Kg. All: sled, arm, vest, camcorder, monitor, accu... Compared to the pro rigs loaded with film camera and all.... my setup is light!
I think I could have use thiner aluminium... At least I'm sure it won't brake! LOL
Glad you liked the video!
Cosmin Rotaru is offline   Reply With Quote
Old April 9th, 2003, 10:19 AM   #34
RED Code Chef
The main thing I keep wondering with these systems is where
people get the vests. Do you/they actually buy a "standard"
steadicam vest and built the rest themselves or is there some
other "secret"?? Prices?
Rob Lohman, visuar@iname.com
Old April 9th, 2003, 10:30 AM   #35
I made that.
some metal plates in front and I also did the sewing myself! ;-)
Not the hardest part on the rig...
check out www.homebuiltstabilizers.com. I learned all I know from there. You can see allot of pics with what others have acomplished. Also, there's a forum where members (like me) are willing to help answering your questions. There are more experimented guys then me on the forum so, come by!
Old April 22nd, 2003, 09:54 AM   #36
Cheapie Steadicam/monopod Rig
I built a cheap steadicam rig with a monopod, but I didnt cut anything.
Home Depot Shopping list:
20 Bumper washers
2" wide aluminum
bolts and washers
Taking 2 inch wide aluminum , cut a chunk 1 ft. long. I measured and drilled two slots- one at each end. Drill one hole directly in the middle. After some finishing and filing, I put a bolt through a stack of bumper washers on each end. You can slide them for balancing now. I took the rubber foot off of the bottom of the monopod, and used that to secure the aluminum foot on. Being the cheap SOB that I am, I just use my two fingers as a gimble under the handle-collar on the monopod. It works reasonably well. There's a slight tendency to "dive" around corners, but then its doable.
Now onto making that jib...
Jeff
Jeff Patnaude is offline   Reply With Quote
Old April 28th, 2003, 12:25 AM   #37
What is this "monopod thing" and where do I find it to alter it???
http://www.veoh.com/channels/filmmaker
My clips and films.
Bob Benkosky is offline   Reply With Quote
Old April 28th, 2003, 12:33 AM   #38
Ok, I found it.... Looks like a tripod with 1 leg.
Yea, I guess you need that piece to put the camera on, the figure out the rest.
Would it just be easier to buy the Steadicam Jr for the GL2???
Is it any good compared to home made stuff???
My clips and films.
Old April 28th, 2003, 01:23 AM   #39
One of the issues with lightweight cameras on a stabilizer is the lack of mass which translates into less inertia, and thus less stable images. The JR deals with this by expanding the masses away from the center. A weighted monopod keeps the masses lined up in the center. Such a design will be inherently less stable. Also, the ideal is to have the masses as far from the fulcrum/balance point as possible, as a mass becomes exponentially more inert by distance from this point. A monopod had fairly equally distributed weight, so you are in essence "throwing away" its weight by having it places it doesn't need to be, meaning you are carrying extra dead weight. In a perfect world, you have the camera on the top, weights in the bottom (preferably useable weight such as batteries) and very little weight inbetween.
Charles Papert
www.charlespapert.com
Old April 28th, 2003, 05:35 PM   #40
Hey Charles
Charles, do you know anything about the Basson? http://www.bassonsteady.com.ar/shop/index.asp
I asked a couple guys who do Steadicam, but they had no information on it. Looks to be a pretty good knock-off of the Steadicam, with a lower price tag.
BTW, I don't believe I have seen this book mentioned in the discussions of camera stabilizers: "Steadicam; Techniqes and Aesthetics" by Serena Ferrara. Maybe the reason is, that it is not very good, since it is short on "techniques," but it does have a reasonably good history of the Steadicam and lots of pictures of G.B.'s early devices, which look amazingly like Glidecams and "home-built" stabilizers. That's right folks, Garrett Brown traveled all these roads long before there were light weight video cameras, and no one has really made any major improvements on his designs, as evidenced by how well his patents held up. Not a perfect book, but certainly of interest.
Wayne
If it was easy, they'd get a relative to do it.
Wayne Orr is offline   Reply With Quote
Old April 29th, 2003, 01:17 AM   #41
Thanks for sending that Basson link Wayne. I'd heard of it but never seen it. For some reason it appears to be one of the least known of the zillion 3rd party rigs out there. It has an interesting look, but of course it's all about performance (and then reliability, service etc...!)
I have Serena's book and have thumbed through it a few times. The interviews are cool but it is a bit of a dry read, as it was originally compiled as a doctorate thesis as I recall. GB is finally getting around to writing his own memoirs, and being a big fan of his way with words, I for one can't wait.
Charles Papert
Old April 30th, 2003, 03:57 AM   #42
The Basson system looks nice. Judging from the OLD (not there anymore) demos on the Basson site (If I were a dealer I'd only put the best demos on my site), the system was crap. Or the operator...
Now, the new clips (with the new system, I gues) are better. I gues the new system IS better!
Still, the operator... just have a look at his hand ("up stairs") on the gimbal. How's that for a light touch? ;-)
