hand made arm at DVinfo.net
Old August 26th, 2012, 12:58 PM   #1
hand made arm
I make hand made steadycam i need help for arm glidecam flycam or any other arm
Does anyone knows users to tell me how many points are in an iron coming into the spring
http://www.dvcity.com/stabilisation-...s/7300-s-8.jpg
Serggio Lamas is offline   Reply With Quote
Old August 26th, 2012, 02:56 PM   #2
Re: hand made arm
Your best bet is the Homebuilt Stabilizers board:
The HBS Group - Index
Charles Papert
www.charlespapert.com
Old August 27th, 2012, 05:13 AM   #3
Re: hand made arm
Hi Serggio
Take it from experience and buy just the arm and vest from Cine City..they will sell it to you without the sled! I have made a couple of DIY arms and the time and effort are not worth it. As Charles suggests go the the HBS forum and the guys there will give you a good insight in what it takes to build a decent arm..some take years to build an arm that works so the much easier way is to buy a ready-made one and re-engineer it to your specs. You will save heaps and time and even save money!!
Just for information each ProAim arm (I have a highly modded one) has an upper and lower bone and they attach to 8 thrust bearings at the end points at either end two of the bearings are joined with a roller shaft inside the bone and the two remaining shafts are static. The Dual springs are connected together by cable which wraps around the roller shafts and the end springs have adjustable threaded rod at each end to adjust tension....just getting someone to make the spring plugs alone is an issue and then you have to find the correct size aluminium channel ...The spring specs alone are a complex mathematical equation and you will end up having to get them specially wound..On my first modified arm I ever bought just getting a spring manufacturer to wind me 4 new springs cost me over $400!!!!
Once you take Charle's advice and visit the HBS forum you will see it's better to buy an arm and vest!!
Chris
Chris Harding is offline   Reply
