X-22 vs. Zephyr, AB vs. V mount, SD vs. HD monitor - Page 2 at DVinfo.net
Old March 25th, 2011, 09:45 PM   #16
Re: X-22 vs. Zephyr, AB vs. V mount, SD vs. HD monitor
Charles, thanks for the rundown.
Glancing back at Bill's original post, I must mention another discovery I made about the Zephyr.
My Zephyr arm will not fly the promoted minimum 5lb payload. The lightest configuration I was able to put on it in testing was about 8 lbs (with two pounds of battery counterweight.) The arm was dialed all the way to its lightest setting.
Bug or feature? Well as I said earlier, I can always add weight (and gain benefits in the process) but sometimes its a real advantage to fly as light as possible.
Mark Schlicher is offline   Reply With Quote
Old March 27th, 2011, 06:18 PM   #17
Mark,
Thanks for the heads up I was thinking the lighter side of the weight scale might present a problem. what are the dimensions if the camera plate I know a 4"x6"x3/8" piece of stainless is around five pounds that would get the rig to a minimum of around 10 lbs..
Bill
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old March 27th, 2011, 07:18 PM   #18
I add a weight plate sold by Steadicam Operator Janice Arthur of Chicago. $210. A steel plate that is tapped like a cheeseplate.
Weight cages and plates - The Steadicam Forum
She makes several, mine is 6.5lbs, which brings an HVX200 to around 14lbs, or a bare DSLR to around 8 (so you still may wan to add some mass). When I flew the 5D, it had rails and bracketry and a Hytron 50 that added another 3lbs or so...so I was in the 11-12lb range with that setup.
There are other, possibly cheaper ways to weight down the stage, but this is versatile and was worth the investment to me. However you do it, make sure it is stable (no flex or vibrations) and safe.
Old March 29th, 2011, 07:35 AM   #19
Mark,
Thanks, but I'll make one for around $70 (material and shipping) add machinist to my list of skills. :)
I tried to view the photo but you need to be registered and I could not find Garrett's surname so it would not accept me. Could you give me the dimensions of the plate you are using?
Thank you,
Bill
Old March 29th, 2011, 11:10 AM   #20
Bill,
If you review the thread I linked, you will see Janice lists all the dimensions of her plates.
Have fun, and post pics!
Old March 29th, 2011, 12:04 PM   #21
Mark I'm sorry I must have scrolled right past it thank you.
Old April 4th, 2011, 10:55 AM   #22
i'm about to post a detailed comparison between the Zephyr SD monitor, the Flyer monitor and a Lilliput monitor on the other Zephyr thread.
Old May 22nd, 2011, 04:13 PM   #23
Originally Posted by Mark Schlicher View Post
The arm is connected to a Garfield mount directly to the Mitchell riser. I previously bought a used Garfield mount and added a Flyer/Zephyr/Scout/Pilot female socket block to it. About $100 for the socket block part number 803-7801. The riser and ubangi and platform were rigged by the Key Grip and provided with the camera car.
As for the monitor, my feeling is that they basically ARE selling it without a monitor. :-) By that I mean, they put their parts and engineering money into the other components to keep the selling price down to $8995.
It's a decision I'm not wild about but I can understand (what I presume to be) their thinking.
At some point, our choice becomes whether to spend a lot of effort worrying about it rather than devoting that time to getting work with the rig. A day or two of paid operating can pay for a pretty sweet replacement monitor. Not that it's not a real issue and irritant.
That doesn't mean we shouldn't voice our concerns, but ultimately its not an un-solvable problem. Just something to be aware of when considering the rig purchase.
I think the person behind you wanted your croissant. XD
David Aronson is offline   Reply With Quote
Old May 22nd, 2011, 09:06 PM   #24
LOL. That's the key grip. If he wanted a croissant, I'd have gotten it for him...always be nice to the guy who rigs your safety harness! :-)
Old June 1st, 2011, 06:10 PM   #25
Edit: Whoops, wrong thread...
