AVPA
Glidecam X10 question
We recently got the X10 and Dean is having troubles balancing it.
It's bouncing as he's walking... What's he doing wrong? He has the FX on the g2000 & the GH1 on the HD4000 - he's adding more weights to 4000 for the Gh to see if that makes a difference. Can anyone help with some tips? |
If you have bounce then you could probably do with more weight on the sled. Then you need to adjust the springs. The arm should be almost level with a slight upwards inclination.
How many springs do you have in each arm section? With the FX1 on a GC4000 you only want one spring per section and enough weights to max it out and still have the arm remain level. If you have both springs then you most likely have too much springyness making it bounce. Also, you will get bound with the GC rig. We had one and it just bounces, no matter how you walk. The Steadicam Pilot is a far superior setup.
mintyslippers.com |
AVPA
Hi Danny,
Thank you for responding. So I think he's weighed it down on the top fairly well now - not sure how many springs in the arms but he has been reading the manual and adjusted them as well as the knobs on the bridge plate. Looking at some clips of people using it, I guess the arms will bounce and perhaps a well trained user will get less. I'm sure the steadicam would be a better setup - a wish list item I think at this stage :) Last edited by Rochelle Morris; January 4th, 2010 at 03:59 AM. |
The X10 is by nature quite springy and bouncy. As noted, the Steadicam products have a far superior design in this regard.
I would recommend dialing down the arm so that it hangs a bit below horizontal, which may require the operator having to provide more of the lift with his own arms. This should help soften the bounciness somewhat, at the expense of greater operator fatigue. It is very possible to get decent results with an X10, but again as noted, it will take quite a bit of practice to dampen the arm's natural tendencies. A softer footstep (more like one would use with handheld shooting) will help also.
Charles Papert www.charlespapert.com |
#5 |
Following on from what Charles has said. I spent a while hanging out on the professional steadicam forums. Nothing quite like hearing how the real pros do thing and they would always argue that when walking with a steadicam you should walk normally (although many videos of them in action show them not walking normally).
Anyway, I quickly realised that if you wanted to walk normally you can only really do so with a large, heavy rig. The smaller rigs for HDV cameras you do need to soften your steps somewhat, even the pilot but only to a small degree. The basic way Steadicams work is they make the camera really heavy, so its harder to move. An 80lb camera is REALLY heavy and its hard to make it move but with our little HDV cams and lighweight rigs they still have that tendancy to move with a slight touch.
mintyslippers.com |
#6 | |||
However, it is true that a lighter rig will be more "touchy" and requires less operator input in pan and tilt. If one was to increase the inertia of a light rig by expanding the masses considerably, you can actual duplicate the feel of a much larger rig without adding significant weight. Those who use the supplied weights on the Pilot can attest that it becomes much "quieter" in feel once you start adding mass to the front and rear of the camera stage and lower spar.
#7 | |||
But even with the extra weights, a light rig like the Pilot is is going to be more difficult to control with your left hand, especially in the tilt axis and roll axis. |
