Balancing Magiqcam with heavy battery - Page 4 at DVinfo.net
Old December 4th, 2004, 07:09 PM   #46
second part of the reference http://www.steadicam-ops.com/docs/t_ultramanual_16-30.pdf
ed
Ed Liew is offline   Reply With Quote
Old December 4th, 2004, 07:42 PM   #47
I posted too soon, got it figured out. Thanks for your responses
Ed!
Michael Best is offline   Reply With Quote
Old December 4th, 2004, 08:56 PM   #48
pictures? new gimbal
ed
Old December 4th, 2004, 09:20 PM   #49
Wei Mun :
I got the Marshall together with the magiqcam from John. PAL.
I'm also trying to get to him through email ... with no luck.
Do more, learn more
Wesley Wong is offline   Reply With Quote
Old December 5th, 2004, 02:23 AM   #50
wesley,
problem with your rig?
ed
Old December 5th, 2004, 03:15 AM   #51
Thanks Ed and Wesley for the response.
I'm still deciding on which brand to buy.
Well at the mean time, might as well get more input from you guys :)
To Ed:
What's the size of the LCD? From the pics you posted, it looks like a 5" or 6". How's the framing like? Guessing it must be overscan, right?
To Wesley:
So, how do you find the Marshall LCD? Is it good in terms of brightness? Also, how do you find the viewing area? 4" seems small.
Well, that's all for now.
Thank you once again.
Wei Mun is offline   Reply With Quote
Old December 5th, 2004, 09:40 AM   #52
Ed :
yeah. still trying to folow up with john regarding missing components to make my low mode (low dog) work.
Wei :
It works for me, especially when that's the only PAL model from John at magiqcam that he sourced into my rig.
might wanna check out others for comparison in person in your country.
Do more, learn more
Old December 5th, 2004, 10:27 AM   #53
I love to post pictures to get some feedback, how can I post them?
Old December 5th, 2004, 10:48 AM   #54
wei mun,
its a 5" mon, overscan and work very well in color mode. not so good in b/w mode outdoor.
wesley,
should post your problem here so that other with low mode can give you a helping hand. other wise, post a message for john like what i did. from my correspondance with him, he said he check into this forum but only thing is he do not post or answer here.
michael,
post the pics on your website or else get a free website and post it there.
ed
Old December 5th, 2004, 03:40 PM   #55
I'm using the Nebtek Neb50 5" monitor on my magiqcam. I also got the 7.2v Li to 12v adaptor which allows me to power it with the same batteries as I use for my camera. Flying a DVX100 on it.
Nebtek Neb50:
http://www.nebtek.com/proddetail.php?prod=100NEB50
Initially I used a Marshall 4" monitor I bought through John but the backlight in it stopped working so I sent it back. My new nebtek works very well so far and is quite affordable.
By the way I'm trying to find out how the best way to setup and use the low mode, haven't really got there yet.
The only way I have found so far is to put the monitor on the camera plate, but then where are you supposed to put the battery?
Johan Lundberg
TECHCREW SWEDEN
Johan Lundberg is offline   Reply With Quote
Old December 5th, 2004, 08:04 PM   #56
Hi there Johan. I tried calling you several times but no answer. Do you still have the same number? BTW, do you have any pics of you magiqcam fully loaded with your setup?
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old December 5th, 2004, 09:05 PM   #57
For those looking at monitors for their rigs, here's an amazing new option:
DVX-Pod
For $600, you get a 6.5" super- high res screen and recording and playback capabilities--excellent for checking your shot inbetween takes. At 21 oz, still considered light but would only be appropriate for cameras over 10 lbs, say.
Charles Papert
www.charlespapert.com
Old February 15th, 2005, 10:01 AM   #58
:( should I be worried ??
about these cracks on my vest , where the arm goes ?
http://home.pacific.net.sg/~jeng_hsiung/PICT0210.JPG
Do more, learn more
Old February 15th, 2005, 10:05 AM   #59
Yep! you should be worrying. when that finally breaks off all those bearings will definately find its way to the floor and then you will have friction. That has to rectified soon.
Charles
Old February 15th, 2005, 10:42 AM   #60
Yikes! Scary!
Charles Papert
Charles Papert is offline   Reply
