Balancing Magiqcam with heavy battery - Page 2 at DVinfo.net
Old November 30th, 2004, 11:18 AM   #16
Sorry about that. I had forgotten about the sipirit level pic. I'll get onto it.
You'll have to have an outside link to link your pics.
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old November 30th, 2004, 12:08 PM   #17
no need to be sorry. You've been most helpful to steady rig newbies like me.
home.pacific.net.sg/~jeng_hsiung/PICT0155.JPG
here's my pic
Do more, learn more
Wesley Wong is offline   Reply With Quote
Old November 30th, 2004, 12:36 PM   #18
Here's the link I put together of the various places to put a bubble level: http://homebuiltstabilizers.com/bubblelevel.html
Charles
Old November 30th, 2004, 12:46 PM   #19
Holy cow--umm--jeez.
Wesley, the monitor and battery are supposed to be at 12 o'clock and 6 o'clock relative to the camera, not 3 and 9.
As far as the level; stick one bubble under the camera mounting platform so that it reads side to side level. Put another on the face of the monitor. Periodically check that they match each other (adjust the monitor one to match the other one). This will give you a hint of when your horizon is level. Having levels in the fore-aft plane is less important because you are likely to be constantly tilting the rig, but rarely wanting to shoot off-level side to side.
Charles Papert
www.charlespapert.com
Old November 30th, 2004, 12:46 PM   #20
First of all Wong. I see your problem already. I don't know if you meant it to be that way but the sled base is positioned wrongly. You have the top stage and the base opposite each other.
thet are supposed to be align with the post in one direction.
Apparently Charles P. post made it before mine. Good to see you CP
Charles
Old November 30th, 2004, 09:24 PM   #21
charles k,
very nice looking bubble level. did you make them?
ed
Ed Liew is offline   Reply With Quote
Old November 30th, 2004, 09:43 PM   #22
Hej Ed. Just to be sure. Are you referring to the one in the first pic or the third?
Charles
Old November 30th, 2004, 10:03 PM   #23
hi charles k,
the third pic.
ed
Old November 30th, 2004, 10:19 PM   #24
It was purchase the way it is.
Charles
Old December 1st, 2004, 12:26 AM   #25
did a search with the link on your homebuilt site and found some very interesting and useful items. you must have spend quick alot of time compiling all the info on your site. great work charles.
ed
Old December 1st, 2004, 01:55 AM   #26
Glad you apprecite it Ed. It took som time but the results does reap... :)
Charles
Old December 1st, 2004, 09:55 AM   #27
Ok I get more balance, now that they are in 12 and 6 o'clock position. Thanks ! What a klutz I am !
But now it seems like my battery mount is in my knees way when I walk and the monitor is no where useful , being obstructed visually by the sled ...
Should I find a way to mount the monitor a little off 12'oclock position and walk funny like a penguin to overcome this ??
Do more, learn more
Old December 1st, 2004, 10:20 AM   #28
Wong. The monitor is suppose to be in front not on the back. In other words, place the monitor at 12 'o clock instead of 6.
Take a look at my pic of my old sled:homebuiltstabilizers.com/mysled.jpg
The monitor is up in front while the anton bauer battery is at the back. In my case, lower at the bottom.
...or this: :homebuiltstabilizers.com/charlesrig25.jpg
Charles
Old December 1st, 2004, 11:21 AM   #29
duh. yes, I get that. my bad for wrongfilly misleading everyone to think I mounted it at 6 o'clock for the monitor ...
monitor IS however still visually obstructed by sled and battery is getting in my knees' way.
the magiqcam isn't fanciful and it does not have laterally space saving tilt arms (unlike your seld/rig Charles K.- nice) that lets you save couple of inches from my kness while I fly them. Instead its a dead horizontal piece for the monitor and a downwards diagonal piece with velcro-ed NP-1 battery for my frezzi light, jutting out from the bottom of the sled...
check out my pic again to see why...
Thus the intuitive way for my , straight out-of-the-box was to wrongfully put the monitor mount and the battery/counter weight mount perpendicular to the fore and aft of the camera sled, to easily see the monitor and also not let a big chunk of battery get in my knees' way
Do more, learn more
Old December 1st, 2004, 11:46 AM   #30
Thanks for the clarification. I can see how your battery is getting in the way of your knees, seeing that it is way out in the back. You could try to draw it closer or try to adapt the connector so it hangs downward instead, similiar to mine. Just a suggestion of course.
This could be a mild case of just trying to get use to it by practicing to avoid it when operating the rig.
Charles
