Balancing Stand For Glidecam or Flycam? at DVinfo.net
Old January 24th, 2009, 09:36 PM   #1
Does anybody know of an inexpensive adapter that will let you put the handle of a Glidecam 4000 or Flycam 5000 into it and then it attaches to a C light stand or mic stand?
I understand this is an excellent tool to use in balancing the stabilizer and also a good safe resting place for the rig when not being used.
I tried ebay but either there are not any there or I am not using the right verbage when I search.
D.J. Ammons is offline   Reply With Quote
Old January 25th, 2009, 01:46 AM   #2
i recommend the turtle stand from steadycam. The base is very low so you can do without sandbags with a 6 ibs camera. The glidecam's balancing handle can fit.
Old January 28th, 2009, 06:24 PM   #3
D.J.,
You can use one of our adapters with either a W I D E base mic stand or a lighting stand. Just remember to weight it properly to protect your investment in case of wind or other unforeseen problems. You know...Murphy's Law.
Tery
Indicam
He's only mostly sDEADy.
sort of from "The Princess Bride"
www.indicam.com
Terry Thompson is offline   Reply
