#16 |
3273
Dave, what is the difference between the one you mention and the 3273?
#17 | |
Amazon.com: Manfrotto 3273 Rapid Connect Adapter w/Sliding Mounting Plate (3272): Electronics Amazon.com: Manfrotto 577 Rapid Connect Adapter w/Sliding Mounting Plate (3433PL): Camera & Photo but that's just looking at the pictures, so I can't be sure. |
#18 | |
It's kind of like buying a pair of snow skis, and then learning how to ski. I wouldn't call it difficult, but it takes some time to get good, and it's fun. You don't have to be really strong, especially it you have good form and balance, but strength doesn't hurt either. You breathe a little heavy sometimes, but you usually have a smile on your face. Skiing is a good analogy. If you are on the fence, spend $500 and take the Steadicam 2-day workshop before you buy a steadicam. They provide the steadicams for you to learn on at the workshop. If you take the workshop, and then decide you want to go for it, the stuff you learned at the workshop will put you way ahead of the game. If you take the workshop and then decide it's not for you, then you've only invested $500 and you know a lot more about it if you ever want to hire a steadicam operator. |
#19 | |
Right out of the box, it will still be better than handheld but if you look at a lot of the "first-time-flying-with-my-new-stabilizer" footage, you will notice a lot of bobbing, side-to-side movement, and rolling in the footage. There is a lot of studying, learning, and getting a feel for how it all works until you get useable and satisfactory footage. As far as learning goes, do a search for all of Charles Papert's posts and you will find a wealth of information and lots of golden nuggets of wisdom and tidbits. |
#20 | |
I have and use the 577 but the 3273 looks longer and costs less(!) |
#21 |
Huh actually i've just released i've got the 3273 and not the 577.. didnt notice the difference in length on the plate. Guess that adds a tiny bit more weight to the top of the sled.
#22 |
Joe, what tripod are you interchanging with your 3273 plate?
#23 |
Im not, im using Miller Tripods, i bought the 3273 just as a quick way of getting the camera off the sled. Its much easier than taking off the top plate.
#24 |
So your camera is dedicated for use only on your Pilot?
Also, when you pack the sled away in the backpack, do you take off the top plate or how are you fitting it back in the case? I'm thinking about cutting some of the foam out so that my quick release adapter with top plate can fit in the backpack. |
#25 |
No its not dedicated at all.. if im bringing my pilot onto a set than people know there is going to be set rig and derig time.
And even then, once you dock the pilot to the stand, slide the camera off, unscrew 1 screw.. screw in the other adapter with 1 screw im only down 1 minute.. Sounds like we shoot different things. Yea i got a blade and cut out part of the foam in the bag so i could fit the sled in with the QR plate on. |
#26 | |||
Amazon.com: Manfrotto 3433PL Quick Release Mounting Plate for 501 & 503 Pro Video Heads: Electronics I'm not sure the weight would make a difference, but it's nice that the 577 has the QR adapter and plate the same length, so you can accurately line them up. This places the mass of the camera on the stage the same way every time, which makes it easier to balance when you unpack the rig. |
#27 | |
#28 |
For those interested, i also just found a down converter made by frezzi that takes 12v down to 7.2v. My local camera store had one in stock out the back by chance. Going to buy the right sized plug for my HVX and then a 2.1mm plug for the top of the pilot.
Should work, but will take my pilot in when we make the cable to make sure everything is sweet. The downconverter is about the size of a standard 12v car plug with 2 cables coming out each end, so it doesnt weigh to much and will hopefully tuck nicely under the sled with some gaff. |
#29 | |
I have the 357PL which is the new version of the 3273 and the plates are not interchangeable, its too wide. Bogen / Manfrotto | 357 Pro Quick Release Adapter with | 357 |
