Steadicam Pilot - Getting Started Q & A - Page 8 at DVinfo.net
Old November 26th, 2008, 09:01 PM   #106
Just took my screw and put it in a lathe.. now it works perfectly! cheers
Joe Lawry is offline   Reply With Quote
Old November 26th, 2008, 09:25 PM   #107
Originally Posted by Dave Gish View Post
Every camera operator should have at least one of these...
Yes indeed, but has your screwdriver been immortalized in TV history??!!!
The very first thing I bought for my own kit (was still using a rental rig) was a mega-screwdriver with a wide bit like the one Dave illustrates but about twice as long. Many cameras back then only had a single mounting point so you had to tighten the crap out of them to keep them from rotating on you. I went for the longest one I could find to maximize torque. This sucker was menacing.
On the pilot of "Scrubs", there was a scene where the Janitor threatens Zach Braff's character with a big screwdriver. The one that the prop department provided was not nearly as imposing so I offered mine up (see it in action here, about :30 into the clip).
Towards the end of the first season, that scene was called back with a new intern arriving at the hospital, and the screwdriver made its second appearance on network TV. Too bad it didn't get residuals.
The story has a tragic end; not long after this my old friend disappeared from my frontbox. Petty thievery brought an end to our long working relationship.
Craftsman Big-Ass Screwdriver: 1988-2002. RIP.
Charles Papert
www.charlespapert.com
Old November 26th, 2008, 10:18 PM   #108
Can't top that! Very cool...
Dave Gish is offline   Reply With Quote
Old February 21st, 2009, 12:43 PM   #109
bump..........
Old February 21st, 2009, 09:22 PM   #110
Dave, this thread is a nice resource that has received good responses so I have stickied it. Mazel tov.
Charles Papert
Old February 22nd, 2009, 03:01 AM   #111
Great thread! Answered a lot of my questions :).
Randy Panado is offline   Reply With Quote
Old February 23rd, 2009, 11:04 AM   #112
I found something in my local hardware store to help stop the camera moving about on the stage.
In the UK in B&Q you can get Draper Slip Mat. Its like a thin, rubbery, foam like substance which feels tacky (sticky). A slice of this under your quickrelease plate (or camera) and it wont budge an inch.
I got a roll of it for about £5 although you only need a small ammount, used the rest on my dash board and rugs :)
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old February 23rd, 2009, 04:36 PM   #113
How many mid weights should I buy if I'm flying a Xh-A1 and plan to later fly an EX-1? Would 2 be enough?
Old February 23rd, 2009, 04:48 PM   #114
I would buy 8. Unfortunately, Tiffen just raised the price on middle weights from $6 each to $25 each, but it looks like you can still get the $6 price here:
Steadicam 801-7920-05 Balance Weights, Steadicam
Old February 23rd, 2009, 09:14 PM   #115
Thanks for the heads up. Does the pilot come with 4 end weights already? If so, I need to call and get my order fixed to include 2 more end weights.
Old February 23rd, 2009, 10:00 PM   #116
The Pilot comes with 4 middle-weights and 4 end-weights. I've ordered an extra 8 middle-weights, for a total of 12. For lighter cameras like the XH-A1, I use all of my weights (12 middle weights, and 4 end weights).
Old February 23rd, 2009, 11:10 PM   #117
Okay sweet. All set then :).
Old May 5th, 2009, 08:24 AM   #118
XHA1 with 35mm Adapter
Has anyone tried using the Pilot with an XHA1 and Letus 35mm adapter? Can it still handle the weight when using a long lens, eg. 300mm f4, approx. 3lbs? Not sure what the entire rig would weigh as I don't currently have an adapter, both it and a stabilizer are on my shopping list, just trying to determine which stabilizer.
Thanks, Rich.
Montauk Rocks - Oscail Films
Richard Siberry is offline   Reply With Quote
Old May 5th, 2009, 09:40 AM   #119
See here:
http://www.dvinfo.net/conf/stabilize...f-adapter.html
Old May 5th, 2009, 10:40 AM   #120
What exactly were you thinking to shoot at 300mm on any type of Steadicam...?!!
Charles Papert
Charles Papert is offline   Reply
