Mount Cam to Mic Stand at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old August 23rd, 2006, 06:53 PM   #1
Is there some kind of tripod type head that will attach to a microphone stand? I think mic stand screws are 5/8".
I'm wanting to attach a small DV cam to something like a mic stand with a heavy disc base (not legs).
I want to put it in a crowded theatre close to the stage and regular tripod legs would get in the way of the crowds.
-Scott
Scott Routt
"Talk is cheap unless you have a lot of audio toys"
Scott Routt is offline   Reply With Quote
Old August 24th, 2006, 12:36 AM   #2
Old Boot
Have you considered "clamps" like these?
http://www.b-hague.co.uk/Mounting%20Brackets.htm
The point being, that IF you can locate an "existing" clamping point then odds are it WILL be out of the way to start with.
Old August 24th, 2006, 05:14 AM   #3
No, I hadn't seen that before. But I see what you mean now. Thanks!
-Scott
Scott Routt
Old August 24th, 2006, 06:51 AM   #4
Found The Solution
A OP-R09M (Microphone Stand Converter for Edirol R-09) will attach to a mic stand and the top can be screwed into the bottom of a small dv cam. And it even swivels. Too bad there are none in stock any where.
Scott Routt
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
