contact admin
Direct Drive Gearmotor Cradle Tilts
ServoCity now offers Direct Drive Gearmotor 4” and 6" Cradle Tilts. This cradle tilt system is compatible with 3-12VDC and 6-12VDC gearmotors. The tilt framework is constructed of 1/4” ABS plastic side plates tied together using 6061 T6 aluminum Actobotics components. The height of the cradle is adjustable by moving the motor and bearing mounts up or down the outside cradle. The inside height is also adjustable so that you can properly center the mass of the object to be tilted about the axis of rotation. The camera plate has numerous 1/4” width slots so that you can balance the mass of the object to be tilted in the forward and aft direction. The wide selection of gearmotors will allow you to tailor the speed of the tilt system to match your application. This tilt can be configured in the overhead or underslung position. The inside cradle has no range limitation (it can rotate a full 360 degrees). The motor is fastened to the outside cradle with the 555132 motor mount and attached to the inside cradle with a 6mm bore set-screw hub. The opposing side is supported by an aluminum shaft that protrudes through 1/4” ball bearing and captured with a 1/4” shaft clamp. Comes in kit form. (The kit does not include gearmotor or pan system).
Direct Drive Gearmotor 4" Cradle Tilt (637122) Direct Drive Gearmotor 6" Cradle Tilt (637124) For questions about the system you can contact tech@servocity.com or 620-221-0123 |
