Video head on sliders (best practices) at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old December 2nd, 2011, 02:17 PM   #1
Forgive me if this has been mentioned before, I tried searching but to no avail.
I have a Manfrotto 701 video head and Konova Slider combination that I really enjoy using. The Konova slider comes with a nice and slim carrying case. My dilemma is attaching the video head. I have to travel with these separated and when on location that's when I screw the head onto the slider base plate.
- Would using a quick release plate to connect/disconnect the video head to the slider be advisable?
- If I continue to screw the head on and off each time should I worry about wearing out the threading?
- Also, what is a good way to pack a video head in a kit full of gear?
Leaving the head on all the time is not an option for me.
- Any recommendations?
JF
John Friedman is offline   Reply With Quote
Old April 15th, 2012, 04:45 AM   #2
Re: Video head on sliders (best practices)
When i use the cineslider, i put a manfrotto QR adapter on the slider and leave it there. (its a bulge in the case but it fits). Then i have a 501 head dedicated specifically to the slider, with a 357 QR plate on the bottom. So, yeah, its doable and I consider it safe. I believe the real danger of a slider is tipping the whole rig over. As long as you keep a hand on it and keep the head balanced as possible, i think it works great.
A bowl adapter on top of a slider, plus a bowl THEN the head puts the camera and head really high off the rig and makes it all topheavy. I wont use a bowl adapter on the slider except when mandatory. The manfrotto 357 QR plates are designed to hold a serious news camera, so the risk of failure due to the plate is negligible in my opinion.
In a pinch, I've put super16 film rigs and a redone with redrock rails on it and it worked well so long as I wasn't doing any tilting. (501 head isn't designed for nearly that much weight). I like the speed and convenience enough that i've been casually looking around for a much beefier head to dedicate to the slider via qr plate.
However, you do lose the ability to ball level the camera, if thats a problem for you.
Not sure if that helped, but at least somebody out there has tried it. hehe.
cheers,
-a
Andrew Dean is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
