Manfrotto 501 quick release plate at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old November 26th, 2009, 10:06 AM   #1
Has anyone used one of these?
Manfrotto by Bogen Imaging | 577 Rapid Connect Adapter | 577
I am looking to go between my 501 tripod and my shoulder brace and using the quick release plate. Not sure what the bottom of this looks like for bolting to my shoulder brace.
Paul Cronin
www.paulcroninstudios.com
Old November 26th, 2009, 10:13 AM   #2
I have one on my monopod, my DVMultirig and my cereal bowl ;-)
Well maybe not the cereal bowl but on the other stuff. It has proven to be invaluable to be able to switch from one to another without fumbling. The actual bottom plate has both a 1/4-20 and a 3/8-16 threaded hole so either of the typical mounting screws supplied with the 501/503 type heads work. I use the 1/4-20. All of my breadloaf cameras have the QR plate and I would be lost without it.
Well worth the money IMO.
Don
Old November 26th, 2009, 11:24 AM   #3
Hi Don thanks for the response.
Great to hear it works well. So you are saying the bottom of the base is secured to your DVMultirig with 1/4-20 or 3/8-16 just like the quick release plate is to the camera?
Paul Cronin
Old November 26th, 2009, 12:44 PM   #4
yep. the multirig has a 1/4-20 screw (bolt) and I have the bottom plate (the actual QR mechanism) attached to it with that. That's where it lives, never comes off. Then when I need to get on the mutlirig (or monopod as that has one also) it's a simple push pull twist and flip ;-). It takes only a few seconds to move from one to the other.
Don
Old November 27th, 2009, 09:16 AM   #5
Thank you Don I now have one on the way.
Paul Cronin
Old November 27th, 2009, 10:52 PM   #6
My quick release bracket has been ordered and is in transit for my DV multirig. I will let you know how it works when it arrives.
Melvin
Melvin Baggs is offline   Reply With Quote
Old November 28th, 2009, 07:17 AM   #7
Just so you know, 1 thing I did was to take the mounting screw, from the multirig, out of the slot and turn the little plate around so the little locking point was at the rear. I then place the QR 577 mount a little further forward and the locking lever doesn't get rubbed raw by the screw lock of the right side handle of the multirig.
Hope that all makes sense. If not let me know I'll try to post a picture or 2.
Don
Old November 28th, 2009, 09:08 AM   #8
Good point Don that makes sense.
Paul Cronin
Old November 28th, 2009, 10:31 AM   #9
EDIT NOTE::::::: in order to do that take a 1/4" drill bit and at the rear of the slot where the mounting screw and plate goes on the multi rig, you need to drill it out. IOW, at the rear of the slot drill it out so the screw will come out OR you stand a chance of stripping the screw. It's just a tiny little bit to drill but it makes a world of difference.
WARNING WARNING WARNING!!!!! Before you DO start drilling just check to make sure you really do need to in case the your's is different than mine. I tried to unscrew the mounting screw from the multirig and found it was quite tight and didn't want to take a chance of stripping it so hence a 1/4" drill bit, a cordless drill and 2 seconds to do it.
Anyway I figured I better mention this before Danny N starts getting all kinds of orders for those mounting screws and starts wondering what the heck is going on. ;-)
Don
Old November 28th, 2009, 10:36 AM   #10
Warning taken,
I would never just start drilling until I knew it was need and there were no other options.
I will know Monday when the quick release arrives and I test out the options.
Paul Cronin
Old December 1st, 2009, 02:25 PM   #11
Quick Release arrived and yes it is worth every penny. Nice addition.
Paul Cronin
Old December 1st, 2009, 02:50 PM   #12
Glad it worked for you. Isn't it nice to be able to go from tripod to rig and back quickly?!
Don
Old December 1st, 2009, 03:06 PM   #13
Thanks Don,
Yes it is great and only takes seconds. Positive lock and easy to use.
Paul Cronin
Old April 9th, 2010, 01:11 PM   #14
I must be really not technically inclined but despite your description I still cannot figure it out.
The only way the tightening knob of 577 can be turned is when 577 is mounted at the maximal forward position in the multirig slot. However this position leaves 2/3 of the adapter hanging out in the front over sloping down part of multirig mounting plate. If I try to move it back the knob is blocked by either the mounting plate or, further back by shoulder support arm.
I am not able to turn around the little blocking plate since there is no hole for the pin to go in?
Andrew Jezierski is offline   Reply With Quote
Old April 9th, 2010, 03:39 PM   #15
a very small allan head wrench is needed to loosen the flip lever on the QR mount. You can then reset the lever to a position where it won't be interfered with when you move it, otherwise you're right. It will rub on the screw on the multirig an be difficult to move plus you'll mess up the finish of the lever.
Don
Don Bloom is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
