Remote control cameras at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old March 28th, 2004, 10:50 AM   #1
Anything new out there?
Is anyone using remote control cameras?
I am interested in setting one up for Wedding Church shots. Maybe something that will transmit the video feed to a monitor I can keep an eye on while I tape with a second camera.
Anyone have any insight?
Mark
Green Novice turning Yellow Pro
Soon to be Ripe - So stand back!
Mark Richman is offline   Reply With Quote
Old March 31st, 2004, 03:04 AM   #2
Hi Mark
Welcome from the UK. I, too, have been thinking about a remote camera (or cameras) for weddings. This will mean that I can cut down on cameramen (my sons) who cannot be relied upon for availability (quite rightly as they have their own lives!).
I’ve been thinking on the following lines and would also welcome any comments from others in the Forum.
B.Hague in the UK sell a pan & tilt head for UKP 125 with a 6-metre control lead. I would mount the camera on this, then the assembly on a tripod, although I’ve been thinking about a universal bracket that could be attached to a suitable stable object, more than 2 metres above floor level. This would give a good sweep of procession, guests etc.
I have a 5.6 inch TFT monitor and have purchased a video sender from Maplins (UK supplier of components etc) for UKP 40. In tests this works perfectly and I can pick up a good picture provided I get clear line of sight. The ideal would be to control both camera and pan/tilt through a radio link and I have been researching possible circuits, using a joystick control and the LANC facility on my GL1. But they are few and far between, none are quite what I want and my technical skills may not be up to it.
I am only at the start of this! As videography is my hobby and not my day job, I get precious little time to develop these ideas. I am hoping to get a robust working solution for the 2005 season, so apart from an idea I can’t give you further information. I am happy to keep you informed of progress if you would like.
Regards.
Tony Hills
Tony Hills is offline   Reply With Quote
Old March 31st, 2004, 02:34 PM   #3
Exactly along my thinking
I should be able to put a small wireless monitor in my pocket and check to make sure my remote camera still has a nice wide shot. I don't need great detail just a good look at the composition of my remote camera shot.
I agree family is hard to count on at times.
Cheers,
Mark
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
