Base plate with 1/4" holes to support head. at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old February 14th, 2009, 09:34 AM   #1
Hey guys,
I have a Sticky Pod set up (pro pack, and some additional accessories) that works well but it has some occasional vibrations that can be solved by one extra support arm that I can't seem to attach (other then by gaff tape).
Stickypods sells a "director package" with a "hub" for close to $700:
Sticky Pod Online Store
(the hub is the black circular thing in the middle with all the 1/4" holes in it...)
While I would have no problem simply buying the hub from them its is only sold as part of the larger package - which I don't need...
Does anyone have any ideas where I may be able to pick something like this up?
-Joe
Joe Voorhees is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
